Hi all. Need some advice. I need a voltage divider to bring 5v down to 3.33v but i only have 1kOhm resistors. i need x1 1kOhm and x1 2kOhm. i was wondering if i could just twist 2 1kOhm's together to get 2k? or am i over thinking this. Oh, i need this for the logic on my bluetooth module.
Take 2 1ks and set them next to each other so the actual resistors are touching.
This is parallel.
Twist the leads together.
Turn your meter to resistance Ω and measure the resistance across the pair.
You'll need to look at them and decide which one has the right price and features, then check the datasheet for it.
You have another thread going for the selection, I think.
Cool.
Come back here after you've looked at the datasheet.
I'm pretty sure that the current across the bridge is factored out of the sum of the voltages, so:
I = V / (r1 + r2)
