voltage in Arduino MKRZero
Warning: Unlike most Arduino & Genuino boards, the MKRZero runs at 3.3V. The maximum voltage that the I/O pins can tolerate is 3.3V. Applying voltages higher than 3.3V to any I/O pin could damage the board.
Does anyone understand that?
If MKRZero runs at 3.3V And in case Applying voltages higher than 3.3V to any I/O pin could damage the board. in this case Why there is a pin (VIN)5V?it's work as only output voltage, right? .and damage is caused by input voltages by other input devices? please answer me!
Hi weal5300,
The 5V output can be useful for powering external breakout boards or shields that require this voltage.
It's necessary to protect the MKRZero's inputs from 5V by using a 5V to 3.3V level shifter, such as the one shown here: 4-channel I2C-safe Bi-directional Logic Level Converter [BSS138] : ID 757 : $3.95 : Adafruit Industries, Unique & fun DIY electronics and kits.
