I have connected my phone to an ESP32 through bluetooth and added a speaker. I also have a HC-SR04 connected. I the volume on the speaker to be controlled by the outputs by the HC-SR04, but it seems like the volume on the phone is overruling the volume set by the HC-SR04.
I am using pschatzmann ESP32-A2DP library.
Is it possible to overwrite the volume set by the phone?
My code is:
#include "BluetoothA2DPSink.h"
BluetoothA2DPSink a2dp_sink;
int volume = 0;
const int trigPin = 5;
const int echoPin = 18;
const int numReadings = 10;
int readings[numReadings];
int readIndex = 0;
int total = 0;
int average = 0;
int minimum = 2;
int maximum = 400;
#define SOUND_SPEED 0.0343
long duration;
float distanceCm;
int power;
int invertPower;
long DSC = 3.1496
void volumeChanged(int newVolume) {
Serial.println(newVolume);
volume = newVolume;
void connection_state_changed(esp_a2d_connection_state_t state, void* ptr) {
Serial.println(a2dp_sink.to_str(state));
void audio_state_changed(esp_a2d_audio_state_t state, void* ptr) {
const i2s_config_t i2s_config = {
.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX | I2S_MODE_DAC_BUILT_IN),
.sample_rate = 44100,
.bits_per_sample = (i2s_bits_per_sample_t)16,
.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
.communication_format = (i2s_comm_format_t)I2S_COMM_FORMAT_STAND_MSB,
.intr_alloc_flags = 0,
.dma_buf_count = 8,
.dma_buf_len = 64,
.use_apll = false
a2dp_sink.set_i2s_config(i2s_config);
a2dp_sink.set_on_volumechange(volumeChanged);
a2dp_sink.set_on_connection_state_changed(connection_state_changed);
a2dp_sink.set_on_audio_state_changed(audio_state_changed);
a2dp_sink.start("Robert");
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(proxLED, OUTPUT);
pinMode(alarmLED, OUTPUT);
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distanceCm = duration * SOUND_SPEED/2;
distanceCm = constrain(distanceCm, minimum, maximum);
total = total - readings[readIndex];
readings[readIndex] = distanceCm;
total = total + readings[readIndex];
readIndex = readIndex + 1;
if (readIndex >= numReadings) {
readIndex = 0;
average = total / numReadings;
power = average * 5;
Serial.print(" Distance (cm): ");
Serial.print(distanceCm);
Serial.print(" │ Average (cm): ");
Serial.print(average);
Serial.print(" │ Voltage (mV): ");
Serial.print(power);
invertPower = map(power, 0, 2000, 2000, 0);
volume = average / DSC;
Serial.print(" │ Volume: ");
Serial.println(volume);
