I am a beginner and want to make a simple volume control for my sound system.
I have a AD5206 Digital pot. I followed this link (http://arduino.cc/en/Tutorial/SPIDigitalPot) and managed to dimm some leds. Now i don't just want this in a loop but to control it with a rotary encoder.
So i got this code (http://bildr.org/2012/08/rotary-encoder-arduino/) and now i can read the rotary encoder. But now i wonder, how do i "merge" these two codes to control two channels of the AD5206 with the rotary encoder? Any inputs?
First: ..it seems a bit odd to me to use a rotatry encoder + dig.pot to make a potensiometer.
I'd understand better if you wantet to use a remote controller for this task..
You have working programs for each of your components.
Then copy one into the other. section by section.
Add the sequence where a given input from your rotart to set the corrensponding output to the dig.pot
Digital Pot Control
This example controls an Analog Devices AD5206 digital potentiometer.
The AD5206 has 6 potentiometer channels. Each channel's pins are labeled
A - connect this to voltage
W - this is the pot's wiper, which changes when you set it
B - connect this to ground.
The AD5206 is SPI-compatible,and to command it, you send two bytes,
one with the channel number (0 - 5) and one with the resistance value for the
channel (0 - 255).
The circuit:
* All A pins of AD5206 connected to +5V
* All B pins of AD5206 connected to ground
* An LED and a 220-ohm resisor in series connected from each W pin to ground
* CS - to digital pin 10 (SS pin)
* SDI - to digital pin 11 (MOSI pin)
* CLK - to digital pin 13 (SCK pin)
created 10 Aug 2010
by Tom Igoe
Thanks to Heather Dewey-Hagborg for the original tutorial, 2005
// inslude the SPI library:
#include <SPI.h>
// set pin 10 as the slave select for the digital pot:
const int slaveSelectPin = 10;
// set the slaveSelectPin as an output:
pinMode (slaveSelectPin, OUTPUT);
// initialize SPI:
SPI.begin();
// go through the six channels of the digital pot:
for (int channel = 0; channel < 6; channel++) {
// change the resistance on this channel from min to max:
for (int level = 0; level < 255; level++) {
digitalPotWrite(channel, level);
delay(10);
// wait a second at the top:
delay(100);
// change the resistance on this channel from max to min:
digitalPotWrite(channel, 255 - level);
delay(10);
void digitalPotWrite(int address, int value) {
// take the SS pin low to select the chip:
digitalWrite(slaveSelectPin,LOW);
// send in the address and value via SPI:
SPI.transfer(address);
SPI.transfer(value);
// take the SS pin high to de-select the chip:
digitalWrite(slaveSelectPin,HIGH);
//From bildr article: http://bildr.org/2012/08/rotary-encoder-arduino/
//these pins can not be changed 2/3 are special pins
int encoderPin1 = 2;
int encoderPin2 = 3;
volatile int lastEncoded = 0;
volatile long encoderValue = 0;
long lastencoderValue = 0;
int lastMSB = 0;
int lastLSB = 0;
Serial.begin (9600);
pinMode(encoderPin1, INPUT);
pinMode(encoderPin2, INPUT);
digitalWrite(encoderPin1, HIGH); //turn pullup resistor on
digitalWrite(encoderPin2, HIGH); //turn pullup resistor on
//call updateEncoder() when any high/low changed seen
//on interrupt 0 (pin 2), or interrupt 1 (pin 3)
attachInterrupt(0, updateEncoder, CHANGE);
attachInterrupt(1, updateEncoder, CHANGE);
void loop(){
//Do stuff here
Serial.println(encoderValue);
delay(1000); //just here to slow down the output, and show it will work even during a delay
void updateEncoder(){
int MSB = digitalRead(encoderPin1); //MSB = most significant bit
int LSB = digitalRead(encoderPin2); //LSB = least significant bit
int encoded = (MSB << 1) |LSB; //converting the 2 pin value to single number
int sum = (lastEncoded << 2) | encoded; //adding it to the previous encoded value
if(sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) encoderValue ++;
if(sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) encoderValue --;
lastEncoded = encoded; //store this value for next time
// hearder removed - see originals
#include <SPI.h>
// for encoder
volatile byte encoderValue = 0; // contains the vaulue to be set to potmeter
// changed from long to byte because pot has only 256 posotions. (knut_ny)
int lastMSB = 0;
int lastLSB = 0;
// end encoder variables
// initialize SPI:
SPI.begin();
// then the encoder
Serial.begin (9600); // can be removed
// REMOVE this for-loop use one og the pots only
digitalPotWrite(channel, encoderValue);
delay(10);
void updateEncoder() //
if(sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) if (encoderValue<254)encoderValue ++;
if(sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) if (encoderValue>0 ) encoderValue --;
// changed above to keep encodervalue in range 0..255 )knut_ny)
If you build this e.g. around a "mini pro" , you may need:
for programmin it (there are ways around it, but this makes it easy and clean)
"Mini pro" can drive 10 (small size, 3mm) LEDS @ 10mA each without additional hardware except resistors
