Wake up/sleep a barcode scanner using UART command
Hello,
I'm an engineering student and i have problems putting a barcode scanner to sleep/wake up. I use a 3,3V arduino MKR WAN 1310, and i need to put a barcode scanner to sleep/wake up. Here is my code so far. The scanning part works fine, but the Serial1.write() does not work at all.
  Serial1.begin(9600);
  while (!Serial);
  delay(1000);  // Initialisation
  if (Serial.available()) {
    String command = Serial.readStringUntil('\n');
    command.trim();
    if (command.equalsIgnoreCase("veille")) {
      Serial.println("Mise en veille du scanner...");
      Serial1.write((0xA5);  // Envoie de l'octet 0xA5 pour mettre en veille
      delay(100);           // Attendre un peu pour permettre au scanner d'entrer en veille
    } else if (command.equalsIgnoreCase("reveille")) {
      Serial.println("Réveil du scanner...");
      Serial1.write(0x00);  // Envoie de l'octet 0x00 pour réveiller le scanner
      delay(100);           // Attendre un peu pour permettre au scanner de se réveiller
      Serial.println("Commande non reconnue");
  lecture();
void lecture() {
  if (Serial1.available()) {
    String receivedData = Serial1.readStringUntil('\n');
    Serial.print("Données reçues : ");
    Serial.println(receivedData);
and here is a picture of the documentation, and a link. https://www.waveshare.com/w/upload/d/dd/Barcode_Scanner_Module_Setting_Manual_EN.pdf
I think i have difficulties understanding how to use the Serial1.write() function, what is the adress? what is bit 7-0??.
Thank you so much for your help ! thank you
Have a look at the write examples on the manual.
I think this would be command for A5:
0x7E, 0x00, 0x08, 0x01, 0x00, 0xD9, 0xA5, 0x3E, 0x69
Thank you this byte sequence worked perfectly! I need to spend time on the doc to understand exactly how to create a byte sequence but i am very thankful!
Wasn't complicated.
0x7E, 0x00, header
0x08, write (07 for read)
0x01, number of bytes
0x00, 0xD9, address
0xA5, byte to write
0x3E, 0x69 checksum (calculated without header)
