Hello I am attempting to wake an esp32 from deep sleep using GPIOs 35 and 36 being pulled low. There is a great tutorial on this, but it requires some understanding of HEX which I don't have.
In the tutorial the author uses GPIO32 and 33 this apparently is a bitmask of 0x300000000 but I am having trouble understanding how to arrive at this conclusion?
The example code given is:
//Pushbuttons connected to GPIO32 & GPIO33
#define BUTTON_PIN_BITMASK 0x300000000
RTC_DATA_ATTR int bootCount = 0;
void setup(){
//Increment boot number and print it every reboot
++bootCount;
Serial.println("Boot number: " + String(bootCount));
//Print the wakeup reason for ESP32
print_wakeup_reason();
//Configure GPIO32 & GPIO33 as ext1 wake up source for HIGH logic level
esp_sleep_enable_ext1_wakeup(BUTTON_PIN_BITMASK,ESP_EXT1_WAKEUP_ANY_HIGH);
//Go to sleep now
esp_deep_sleep_start();
void loop(){}
//Function that prints the reason by which ESP32 has been awaken from sleep
void print_wakeup_reason(){
esp_sleep_wakeup_cause_t wakeup_reason;
wakeup_reason = esp_sleep_get_wakeup_cause();
switch(wakeup_reason)
case 1 : Serial.println("Wakeup caused by external signal using RTC_IO"); break;
case 2 : Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
case 3 : Serial.println("Wakeup caused by timer"); break;
case 4 : Serial.println("Wakeup caused by touchpad"); break;
case 5 : Serial.println("Wakeup caused by ULP program"); break;
default : Serial.println("Wakeup was not caused by deep sleep"); break;
