Waking up from Pin 2...
I have a Arduino Uno, with a SparkFun PIR sensor attached on PIN 2.
I set up the PIR so its working correctly and it detects motion on LOW, but when I put the Arduino to Sleep sleep.sleepInterrupt(0,LOW); it never wakes up…
Whats wrong with this picture? The PIR works flawlessly on its own…
I basically want to save as muh power consumption as possible until the PIR says … something moved… wake up and do something!
Thanks in advance!
#include <Sleep_n0m1.h>
Sleep sleep;
// Pin for PIR sensor
int alarmPin = 2;
int alarmValue = 0;
   // Set up PIR PIN and give 2 seconds for it to take a room snapshot
   pinMode(alarmPin, INPUT);
   // turn on internal pull-up resistor
   digitalWrite(alarmPin, HIGH);
   delay (2000);
   alarmValue = digitalRead(alarmPin);
   if (alarmValue == LOW)
      Serial.println("Motion Detected");
  delay(100); ////delays are just for serial print, without serial they can be removed
  Serial.println("execute your code here");
  Serial.print("Sleeping Till Interrupt");
  delay(100); //delay to allow serial to fully print before sleep
  sleep.pwrDownMode(); //set sleep mode
  sleep.sleepInterrupt(0,LOW); //sleep for: sleepTime
DOES the PIR gets a voltage, otherwise it cannot give a signal...
maybe this page has some tips - http://www.gammon.com.au/forum/?id=11497 -
What happens if you change the PIR with a switch for debugging? Does it trigger the interrupt when set to low? Also reading the Sparkfun page did you consider this:
The alarm pin is an open collector meaning you will need a pull up resistor on the alarm pin. The open drain setup allows multiple motion sensors to be connected on a single input pin. If any of the motion sensors go off, the input pin will be pulled low.
Considering the pin is low(movement detected) does this will wake up the processor or sleep it? I don't know that library What parameters are expected ( what is 0, and what is LOW) where in code you say to expect the interrupt is triggered on pin 2? What I know about interrupts you need to tell were the interrupt pin is attached. Shouldn't be something like
sleep.sleepInterrupt(2,HIGH); //sleep for: sleepTime
