Want to print some sensor value using > and < and print sum total
I have an infrared emitter and receiver. I want to detect some object and calculate electrical probe changes on serial monitor while passing in front of IR sensor. Each object has a different value when passed, Object doesn't pass continuously but one by one.
I am trying to write a code using following condition.
// If analogRead < 35, Serial Print 0.
// if analogRead > 35 start sum, and < 35 stop sum.
I want to sum the values ​​between "start sum" and "stop sum" and print the total value.
//Else print 0.
Please show us your efforts.
Discuss about the code without the code itself is pointless.
@mustkimdhukka
Your duplicate post has been deleted
I am trying the below code but not getting the total sum
int sum = 0;
  int ifRead = analogRead(A0);
  if (ifRead < 35) {
    Serial.println("0");
    sum = 0; // reset the sum
  else {
    sum += ifRead;
    if (sum >= 35) {
      Serial.println(sum);
  delay(100);
If you only have 2 conditions you only have to test for one of them. :nerd_face:
Twice in this case. :thinking:
     // if sum, print sum, sum=0,
     // else, print sum
// else, sum += analogRead
Your sum is not increasing because you zero sum in every condition (<35 and >=35). Here is a simulation that has removed the sum = 0; from >=35:
