Was not declared in scope
I have just started programming with the Arduino Uno and have had good success using the examples that came with the kit. I am trying to expand on the projects but I am having a trouble with the sketch. I get an Error message"ledPin2 was not declared in this scope" . Can any one point out what I am missing?
int sensorPin1 = 0;
int ledPin1 = 13;
int ledpin2 = 12;
int sensorValue1 = 0;
  pinMode(ledPin1, OUTPUT);
  pinMode(ledPin2, OUTPUT);
 int threshold1 = 150;
 int threshold2 = 180;
 if(analogRead(sensorPin1) > threshold1){ digitalWrite(ledPin1, HIGH);}
 else{ digitalWrite(ledPin1, LOW);}
 if(analogRead(sensorPin1) > threshold2){ digitalWrite(ledPin2, HIGH);}
 else{ digitalWrite(ledPin2, LOW);}
 float temperature = getVoltage(sensorPin1);
 temperature = (temperature - .5) * 100;
 Serial.println(temperature);
float getVoltage(int pin){
 return (analogRead(pin) * .004882814);
Case sensitivity
int ledpin2 = 12;
You probably meant int ledPin2 = 12; as that is what you called it else where in your sketch. C/C++ is case sensitive.
Lefty
Wow thanks for the help. I must be going bug eyed. I looked at that a 100 times and couldnt see that.
thanks
