Was not declared in the scope error
Hey so I am very new into arduino and took a shot at my first project which is the Arduinoboy. This is not at all my code and have no experience in coding and I'm still trying learn how to. This is not my code and I'm not sure how to fix it, but it keeps giving me the error that, 'pinStatusLed' was not declared in the scope. I have no idea how to fix it or what to add. Can anyone fix the code or know what to add or change?
void modeLSDJSlaveSyncSetup()
digitalWrite(pinStatusLed,LOW);
pinMode(pinGBClock,OUTPUT);
digitalWrite(pinGBClock,HIGH);
#ifdef USE_TEENSY
usbMIDI.setHandleRealTimeSystem(usbMidiLSDJSlaveRealtimeMessage);
#endif
blinkMaxCount=1000;
modeLSDJSlaveSync();
void modeLSDJSlaveSync()
while(1){ //Loop forever
modeLSDJSlaveSyncUsbMidiReceive();
if (serial->available()) { //If MIDI Byte Availaibleleleiel
incomingMidiByte = serial->read(); //Read it
if(!checkForProgrammerSysex(incomingMidiByte) && !usbMode) serial->write(incomingMidiByte); //Send it back to the Midi out
if(incomingMidiByte & 0x80) { //If we have received a MIDI Status Byte
switch (incomingMidiByte) {
case 0xF8: //Case: Clock Message Recieved
if((sequencerStarted && midiSyncEffectsTime && !countSyncTime) //If the seq has started and our sync effect is on and at zero
|| (sequencerStarted && !midiSyncEffectsTime)) { //or seq is started and there is no sync effects
if(!countSyncPulse && midiDefaultStartOffset) { //if we received a note for start offset
//sendByteToGameboy(midiDefaultStartOffset); //send the offset
sendClockTickToLSDJ(); //send the clock tick
updateVisualSync();
if(midiSyncEffectsTime) { //If sync effects are turned on
countSyncTime++; //increment our tick counter
countSyncTime = countSyncTime % countSyncSteps; //and mod it by the number of steps we want for the effect
case 0xFA: // Case: Transport Start Message
case 0xFB: // and Case: Transport Continue Message
sequencerStart(); // Start the sequencer
case 0xFC: // Case: Transport Stop Message
sequencerStop(); // Stop the sequencer
default:
if(incomingMidiByte == (0x90+memory[MEM_LSDJSLAVE_MIDI_CH])) { //if a midi note was received and its on the channel of the sync effects channel
midiNoteOnMode = true; //turn on note capture
midiData[0] = false; //and reset the captured note
midiNoteOnMode = false; //turn off note capture
} else if(midiNoteOnMode) { //if we've received a message thats not a status and our note capture mode is true
if(!midiData[0]) { //if there is no note number yet
midiData[0] = incomingMidiByte; //then assume the byte is a note and assign it to a place holder
} else { //else assumed velocity
if(incomingMidiByte > 0x00) {
getSlaveSyncEffect(midiData[0]); //then call our sync effects function
setMode(); //Check if the mode button was depressed
updateStatusLight();
sendClockTickToLSDJ is a lovely loving simple function I wish they where all this short
Technicallyly we are sending nothing but a 8bit clock pulse
void sendClockTickToLSDJ()
for(countLSDJTicks=0;countLSDJTicks<8;countLSDJTicks++) {
GB_SET(0,0,0);
GB_SET(1,0,0);
getSlaveSyncEffect receives a note, and assigns the propper effect of that note
void getSlaveSyncEffect(byte note)
switch(note) {
case 48: //C-3ish, Transport Start
sequencerStart();
case 49: //C#3 Transport Stop
sequencerStop();
case 50: //D-3 Turn off sync effects
midiSyncEffectsTime = false;
case 51: //D#3 Sync effect, 1/2 time
midiSyncEffectsTime = true;
countSyncTime = 0;
countSyncSteps = 2;
case 52: //E-3 Sync Effect, 1/4 time
countSyncTime = 0;
countSyncSteps = 4;
case 53: //F-3 Sync Effect, 1/8 time
countSyncTime = 0;
countSyncSteps = 8;
default: //All other notes will make LSDJ Start at the row number thats the same as the note number.
midiDefaultStartOffset = midiData[0];
void usbMidiLSDJSlaveRealtimeMessage(uint8_t message)
switch(message) {
case 0xF8:
updateVisualSync();
sequencerStop();
void modeLSDJSlaveSyncUsbMidiReceive()
#ifdef USE_TEENSY
while(usbMIDI.read(memory[MEM_LSDJSLAVE_MIDI_CH]+1)) {
switch(usbMIDI.getType()) {
case 0x90: // note on
getSlaveSyncEffect(usbMIDI.getData1());
case 0: // note on
case 3: // CC
case 4: // PG
case 5: // AT
case 6: // PB
#endif
#ifdef USE_LEONARDO
midiEventPacket_t rx;
do
rx = MidiUSB.read();
uint8_t ch = rx.byte1 & 0x0F;
if (ch == memory[MEM_LSDJSLAVE_MIDI_CH] && rx.header == 0x09)
getSlaveSyncEffect(rx.byte2);
switch (rx.byte1)
case 0xF8:
if ((sequencerStarted && midiSyncEffectsTime && !countSyncTime) //If the seq has started and our sync effect is on and at zero
if (!countSyncPulse && midiDefaultStartOffset)
updateVisualSync();
if (midiSyncEffectsTime)
sequencerStop();
} while (rx.header != 0);
#endif
You should post the whole program. Read the how to use this forum-please read sticky to see how to properly post code. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code. If the code is too large to post it can be attached. Better yet, make a minimal verifiable program that shows the problem.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Where in the code that you did not post is pinStatusLed declared. It must be declared somewhere.
That isn't the complete program and pinStatusLed certainly isn't defined anywhere in the code you posted. Are there any other lines somewhere in the program that contain 'pinStatusLed'? If so where? If not then that's what the problem is.
Steve
serial is not the same thing as Serial
Hard to tell if that is important here.
Please remember to use code tags when posting code
