Was not declared in this scope --
Hi All,
I am getting the above error for the simple sketch below:
#include <SoftwareSerial.h>
  SoftwareSerial myserial(0, 1); // set the serial connection
  myserial.begin(9600); // start serial connection with 9600 baud rate
  myserial.println("helloworld!"); // print "helloworld" to serial
  delay(1000); // delay 1000ms
find the error below:
C:\Users\M17 R3\Documents\Arduino\sketch_apr05a\sketch_apr05a.ino: In function 'void loop()':
sketch_apr05a:19:3: error: 'myserial' was not declared in this scope
C:\Users\M17 R3\Documents\Arduino\sketch_apr05a\sketch_apr05a.ino:19:3: note: suggested alternative: 'Serial'
   Serial
exit status 1
option enabled in File -> Preferences.
Thank you
You declared myserial in setup() rather than globally. What board are you using? 0 and 1 pins are the hardware serial on most boards.
Objects that are declared inside a function follow the same scoping rules as variables (cause they are the same). Here is a good page on scope (object visibility and lifetime).
From the Useful links page.
