Waveshare 2.4" ILI9341 problems with ESP32
I've been trying to get my LCD to work for hours, checking wiring, checking code, making small changes, etc. but nothing is working. When I plug in the ESP32 that I'm using (ESP32-S3, Amazon.com: MusRock ESP32-S3-N16R8 Na IoT Development Board with Wi- Fi + BLE, Pre-Soldered AI Module : Electronics), the LCD turns on and stays blank white no matter what code I feed into it. (And my keypad won't read the bottom row for some reason)
Here's the code I have so far:
#include <Keypad.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
#include <SPI.h>
// SINGLE PINOUT
#define LED_PIN 4
#define SERVO 5
#define BUZZER 6
#define DEFUSE 7
#define TOGGLE_1 15
#define TOGGLE_2 16
// LCD PINOUT
#define LCD_CS 10
#define LCD_DC 9
#define LCD_RST 18
// RC522 PINOUT
#define RC522_CS 14
#define RC522_RST 8
// KEYPAD PINOUT
#define R1 45
#define R2 46
#define R3 21
#define R4 37
#define C1 38
#define C2 39
#define C3 41
#define C4 42
// SHARED
#define SPI_MOSI 11
#define SPI_SCK 12
#define SPI_MISO 13
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {{'1', '2', '3', 'A'},
                         {'4', '5', '6', 'B'},
                         {'7', '8', '9', 'C'},
                         {'*', '0', '#', 'D'}};
byte rowPins[ROWS] = {R1, R2, R3, R4};
byte colPins[COLS] = {C1, C2, C3, C4};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
String input = "";
Adafruit_ILI9341 tft(LCD_CS, LCD_DC, LCD_RST);
  Serial.println("BOOT");
  pinMode(LCD_RST, OUTPUT);
  digitalWrite(LCD_RST, LOW);
  delay(100);
  digitalWrite(LCD_RST, HIGH);
  delay(200);
  tft.begin();
  tft.setRotation(1);
  tft.fillScreen(ILI9341_RED);
  Serial.println("DISPLAY OK");
  char key = keypad.getKey();
  if (key) {
    readKeypad(key);
    updateDisplay();
    delay(100);
void readKeypad(char key) {
  switch(key) {
    case '#':
      input = "";
    case '*':
    default:
      input += key;
void updateDisplay() {
  tft.fillScreen(ILI9341_BLACK);
  tft.setTextColor(ILI9341_RED);
  tft.setTextSize(2);
  tft.setCursor(20, 20);
  tft.print(input);
  Serial.println(input);
I see you've #defined these values; where do you use them? They don't appear to be the default SPI pins for an ESP32. Where do you inform the libraries for any SPI devices you have that these are the pins they should be using?
use all the spi pins in the constructor
Adafruit_ILI9341(int8_t _CS, int8_t _DC, int8_t _MOSI, int8_t _SCLK,
int8_t _RST = -1, int8_t _MISO = -1);
After adding a line to initialize the SPI stuff and removing the code manually controlling the RST on boot, the LCD works now.
Here's the code changes that got it working:
Adafruit_ILI9341 tft(LCD_CS, LCD_DC, -1);
  SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI, LCD_CS);
  tft.begin();
  tft.setRotation(1);
