Depending on the software implementing the server, it may not be written to support multiple client connections, or if you’re lucky, within the initialisation code there might be a value that allows you to set the maximum number of simultaneous connections.
The reason may be either be to contain memory usage, or just to simplify the server code.
Sorry I forgot to include the code. The ESP8266WebServer library is a total mystery to me so if it has limitations - or settings that can be changed - I'd be lost.
#include <ESP8266WebServer.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme;
float temperature, humidity, pressure, altitude;
/*Put your SSID & Password*/
const char* ssid = "YourNetworkName"; // Enter SSID here
const char* password = "YourPassword"; //Enter Password here
ESP8266WebServer server(80);
delay(100);
bme.begin(0x76);
Serial.println("Connecting to ");
Serial.println(ssid);
//connect to your local wi-fi network
WiFi.begin(ssid, password);
//check wi-fi is connected to wi-fi network
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected..!");
Serial.print("Got IP: "); Serial.println(WiFi.localIP());
server.on("/", handle_OnConnect);
server.onNotFound(handle_NotFound);
server.begin();
Serial.println("HTTP server started");
server.handleClient();
void handle_OnConnect() {
temperature = bme.readTemperature();
humidity = bme.readHumidity();
pressure = bme.readPressure() / 100.0F;
altitude = bme.readAltitude(SEALEVELPRESSURE_HPA);
server.send(200, "text/html", SendHTML(temperature,humidity,pressure,altitude));
void handle_NotFound(){
server.send(404, "text/plain", "Not found");
Its only refreshing once a second. I could easily reduce that if that is the problem. @DaveE I have a spare ESP32 WROOM 32 DEVKIT C - I'll try the AsyncServer on that.
