Web Service
Somebody knows ? How can I send some data to web service from arduino uno ? I want to open relay if username and password are true on remote web service ?
have a look at this page;
http://arduino.cc/en/Tutorial/XivelyClientString
I must send data to dotnet web service. how can I make it ? please help ?
how can I make it ?
Use a text editor.
If you want more help, provide more details.
Aleyna:
You need to either learn to do it, or find somebody to do it for you. Note that most people would expect to be paid for working for you, but if you're willing to pay then the Gigs & Collaborations section is the place to ask.
If you're doing it yourself and run into a problem then there are plenty of people here who will be willing to help you solve the problem, but you need to demonstrate that you're actually doing it yourself and have made a reasonable effort to solve the problem for yourself. You haven't done that yet.
ws.example.com/service.aspx
strtextbox:
linkbutton1:
labelfinished
I want to send 12345 strings to strtextbox and then push linkbutton1 on ws.example.com/service.aspx from my arduino, if my strings is 12345, labelfinished will back to me true, if my string is not 12345, labelfinished back to me false. I want to make this sketch web site is working perfectly. but arduino didnt worked :frowning: please help. I tried to connect with arduino web client example, not working :frowning: it says only
connecting...
connected...
disconnecting..
Simple client test code you can try to see if you get a response from the server.
//zoomkat 9-22-12
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
//remove SD card if inserted
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "web.comporium.net"; // zoomkat's test web page server
EthernetClient client;
void setup(){
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  Serial.println("Better client test 9/22/12"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.1"); //download text
    client.println("Host: web.comporium.net");
    client.println("Connection: close");  //close 1.1 persistent connection
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
nothing happens :frowning:
char server[] = "ws.example.com/webservicetest.asmx";
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192,168,0,3);
IPAddress gateway(192,168,0,1);
IPAddress subnet(255,255,255,0);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip, gateway, subnet);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
// Make a HTTP request:
client.print("GET /ws.example.com/webservicetest.asmx?String1=12345");
client.println(" HTTP/1.1");
client.println("Host: ws.example.com");
client.println("Content-Type: text/xml; charset=UTF-8");
client.println("Content-Length: length");
client.println();
else {
// if you didn't get a connection to the server:
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
client.stop();
// do nothing forevermore:
while(true);
nothing happens
That isn't the name of the server. That's that name of the service running on the server.
The GET request specifies the name of the script execute on the server you already connected to.
How many bytes would that be?
In any case, something happened. You need to be a lot more specific about what happened.
It is also unlikely that the service expects just an argument like that. Services normally expect a SOAP packet.
Forget the Arduino for a while. Concentrate on getting the PC to connect to the server, pass data to the service, get a response from the service and parse the response. When that works, making the Arduino do the same thing(s) will be a lot easier.
