Webserver, HTML serial print problem
Hello, I have a simple webserver that I want to print the number entered in the webpage on a serial monitor with a message.
Webpage control code that is asking for the input
            client.println("<form action='/' methode=post>");
            client.println("<label for='A'>Enter number: </label>");
            client.println("<input type='number' id='N' name='N'>");
            client.println("<input type='submit' value='Enter'>");
            client.println("</form>");
The part that checks for the input and prints the information to the serial monitor
        if (currentLine[6] == 'N') {
          String myString = currentLine;
          myString.remove(0, 8);
          Serial.print("Number enterd is:" + myString + "/n" );
The results that I'm getting in the serial monitor as shown below:
You enterd:
You enterd:
You enterd:3
You enterd:3
You enterd:3 H
You enterd:3 HT
You enterd:3 HTT
You enterd:3 HTTP
You enterd:3 HTTP/
You enterd:3 HTTP/1
You enterd:3 HTTP/1.
You enterd:3 HTTP/1.1
The results I want the serial monitor to display:
You enterd:3
Any help would be appreciated.
The results you show are clearly the consequence of a part of the code that you haven't shown us. Where is 'currentline' assigned it's value ?
For debugging purposes, it is practical to change the method to 'get', so you actually see that the form is returning the correct URL (i think it sort of is, but just to be sure...)if (currentLine[6] == 'N')This is a rough method, you are better of using indexOf()
I changed it to the indexOF, thanks!
Here is the entire code:
#include <WiFi.h>
const char *ssid = "";
const char *password = "";
WiFiServer server(80);
  Serial.begin(57600);
  delay(10);
  WiFi.begin(ssid, password);
  server.begin();
  // listen for incoming clients
  WiFiClient client = server.available();
  if (client) {
    String currentLine = "";
    // an http request ends with a blank line
    //boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        // if gotten to the end of the line (received a newline character) and the line is blank, the http request has ended, so you can send a reply
        if (c == '\n') {                    // if the byte is a newline character
          // send a standard http response header
          if (currentLine.length() == 0) {
            client.println("Content-type:text/html");
            client.println();
            // the content of the HTTP response follows the header:
            client.println("<!DOCTYPE HTML>");
            client.println("<html>");
            client.println("<h1>  Webpage Controller </h1>");
            client.println("
            client.println("<form action='/' methode=get>");
            client.println("<label for='N'>Enter number: </label>");
            client.println("</html>");
            // The HTTP response ends with another blank line:
            client.println();
            break;    // break out of the while loop:
          else {    // if you got a newline, then clear currentLine:
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
        // Check the client request
       if (currentLine.indexOf('N', 0)== 6) {
          Serial.print("You enterd:" + myString + "\n");
    // close the connection:
    client.stop();
The code I'm using
#include <WiFi.h>
  delay(10);
  server.begin();
  if (client) {
            client.println();
            client.println("
            client.println();
            currentLine = "";
        if (currentLine.indexOf('N') == 6) {
    client.stop();
You enterd:
You enterd:
You enterd:3
You enterd:3
You enterd:3 H
You enterd:3 HT
You enterd:3 HTT
You enterd:3 HTTP
You enterd:3 HTTP/
You enterd:3 HTTP/1
You enterd:3
Your code that prints to the serial monitor gets executed each time through this loop
So the code reads in 1 char, processes it and then executes your print statement. You really only want to do that after you have read in the entire line, not after every char. Possibly as an else{} clause to the if(client.available()){}
Duplicate topics merged
Why did you start a second one after a week ?
Something like this is what I think you need (compiles but not tested)
#include <WiFi.h>
  delay(10);
  server.begin();
// read client until until_c char found, returns true when found else false
// non-blocking, until_c is returned as last char in String, updates input String with chars read
bool readStringUntil(String& input, char until_c, WiFiClient &client) {
  while (client.available()) {
    input += c;
    if (c == until_c) {
      return true;
  return false;
  if (client) {
      if (readStringUntil(currentLine, '\n', client)) {
        // got line process it
        // note current line has '\r''\n' if in the stream
        currentLine.trim(); // remove \r \n
        } else if (currentLine.length() == 0) {
          // send response .... your response code here
        currentLine = ""; // finished with this line
    client.stop();
see Arduino Software Solutions for various examples of how to read in text
Thank you so much! This fixed the issue. I'm getting this response now:
You enterd:23 HTTP/1.1
Do you know how do I get rid of the HTTP/1.1?
drmpf:
#include <WiFi.h>
 delay(10);
 server.begin();
   input += c;
   if (c == until_c) {
     return true;
 return false;
if (client) {
   client.stop();
see [Arduino Software Solutions](https://www.forward.com.au/pfod/ArduinoProgramming/SoftwareSolutions/index.html) for various examples of how to read in text
blh64:
Thank you, this helped me narrow down the issue, but I used the code posted by drmpf and it fixed it.
UKHeliBob:
I wasn't getting any help, and I couldn't figure it out on my own
try
int spaceIdx = currentLine.indexOf(' ');
currentLine.remove(spaceIdx); // remove the rest
OR
currentLine.replace("  HTTP/1.1","");
This works. Thank you!
