#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <WebSocketsServer.h>
const char *ssid = "SSID"; //Hotspot SSID
const char *pass = "Password"; //Hotspot password
IPAddress local_ip(192,168,0,1);
IPAddress gateway(192,168,0,1);
IPAddress subnet(255,255,255,0);
WebSocketsServer webSocket = WebSocketsServer(81); //websocket init with port 81
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length) {
Serial.println("web socket method called");
String cmd = "", id = "", password = "", uid = "";
bool states;
switch(type) {
case WStype_DISCONNECTED:
Serial.println("Websocket is disconnected");
webSocket.close();
startLocalHostConnection();
case WStype_CONNECTED:{
Serial.println("Websocket is connected");
Serial.println(webSocket.remoteIP(num).toString());
webSocket.sendTXT(num, "connected");}
case WStype_TEXT:
cmd = "";
for(int i = 0; i < length; i++) {
cmd = cmd + (char) payload[i];
if(cmd == "close") {
WiFi.softAPdisconnect(true);
ESP.reset();
id = getValue(cmd, '\n', 0);
password = getValue(cmd, '\n', 1);
uid = getValue(cmd, '\n', 2);
Serial.println(id);
Serial.println(password);
Serial.println(uid);
if(eeprom.updateIdPassword(id, password, uid)) {
webSocket.sendTXT(num, "success");
// ESP.reset();
else {
webSocket.sendTXT(num, "failed");
// ESP.reset();
case WStype_FRAGMENT_TEXT_START:
case WStype_FRAGMENT_BIN_START:
case WStype_BIN:
hexdump(payload, length);
default:
void startLocalHostConnection() {
webSocket.begin(); //websocket Begin
webSocket.onEvent(webSocketEvent); //set Event for websocket
WiFi.softAP(ssid, pass); //turn on Hotspot
WiFi.softAPConfig(local_ip, gateway, subnet); //set Static IP gateway on NodeMCU
This is my minimal code, I want some I/O events between my Flutter app and ESP8266 board, some days ago It's working fine but now its always disconnecting, even after connecting to ESP hotspot I try to open "http://192.168.0.1:81" manually but it showing site can't be reached. Please help me in this situation.
