Continuing the discussion from No values seen in IoT cloud:
Hi, similar problem, values not updating in the web or app dashboard. Everything else works fine. The serial monitor weighs and displays the reading and connections, the SMS function works but the dashboard is showing 0. Have declared the variables globally as suggested, except for the < int upperlimit >, which I think, shouldn't matter. Can someone please help me as to where I am going wrong> Here's the code:
Sketch generated by the Arduino IoT Cloud Thing "Weightscale"
https://create.arduino.cc/cloud/things/f6787cc2-8e93-4138-89e3-e9f23dd83166
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
float mass;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <ESP8266WiFi.h>
#include <HX711.h>
const char* ssid ="Hidden";
const char* password = "Hidden";
const char* host = "maker.ifttt.com";
HX711 scale;
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN = 4;
const int LOADCELL_SCK_PIN = 5;
//define the parameters for the IFTTT
#define HOSTIFTTT "maker.ifttt.com"
#define EVENTO "Weightscale"
#define IFTTTKEY "9X9uqsXq6O5F8XJU_49NW"
WiFiClient client;
boolean alreadyRun = false;
float reading;
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
//Serial.begin(38400);
//delay(5000);
Serial.println("HX711 Demo");
Serial.println("Initializing the scale");
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
Serial.println("Before setting up the scale:");
Serial.print("read: \t\t");
Serial.println(scale.read()); // print a raw reading from the ADC
Serial.print("read average: \t\t");
Serial.println(scale.read_average(20)); // print the average of 20 readings from the ADC
Serial.print("get value: \t\t");
Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight (not set yet)
Serial.print("get units: \t\t");
Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight (not set) divided
// by the SCALE parameter (not set yet)
scale.set_scale(-104625.f); // this value is obtained by calibrating the scale with known weights; see the README for details
scale.tare(); // reset the scale to 0
Serial.println("After setting up the scale:");
Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight, set with tare()
Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight, divided
// by the SCALE parameter set with set_scale
Serial.println("Readings:");
ArduinoCloud.update();
// Your code here
Serial.print("The weight in kg is:\t");
reading = (scale.get_units(5)); // Assign Weight to reading
Serial.println(reading);
int upperLimit = 2;
if(reading > upperLimit && alreadyRun == false)
sendSMS();
alreadyRun = true;
else {
Serial.println("Still running loop()");
if(reading < upperLimit && alreadyRun == true)
alreadyRun = false;
void sendSMS()
Serial.println("Initiating to send SMS");
WiFi.begin(ssid, password);
Serial.println(" ");
Serial.print("Waiting to connect to WiFi....");
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.print("");
Serial.print("Connected to ");
Serial.print(ssid);
Serial.print("IP address: ");
if (client.connected())
client.stop();
client.flush();
if (client.connect(host,80))
Serial.println("Connected");
// build the HTTP request
String toSend = "GET /trigger/";
toSend += EVENTO;
toSend += "/with/key/";
toSend += IFTTTKEY;
toSend += "?value1=";
toSend += reading;
toSend += " HTTP/1.1\r\n";
toSend += "Host: ";
toSend += HOSTIFTTT;
toSend += "\r\n";
toSend += "Connection: close\r\n\r\n";
client.print(toSend);
Serial.print("SMS Sent");
client.flush();
client.stop();
