Weird behaviour of the Atmega328p Timer1 in CTC mode
I am using Arduino Pro Mini with Atmega328P, 3.3V, 8MHz. I need it to generate permanently a 125kHz square wave. For that, I use the 16-bit Timer1 in the CTC mode with output to OC1A connected to pin 9. (Why the 16-bit timer? Because Timer0 is used by the core for micros(), and Timer2 uses either the MOSI or INT1 pins, which I need for something else.)
Here's what I do:
  // Timer 1, CTC: 125 kHz carrier:
  OCR1A = 31; // This divides the timer frequency -- 8MHz -- by 32*2 = 64
  TCCR1A = bit(COM1A0); // Toggle
  TCCR1B = bit(WGM12) | bit(CS10);
  pinMode(9, OUTPUT);
This is supposed to generate what I need, but instead I get a wave of about 4MHz, no matter what value I put into OCR1A. It was very puzzling and frustrating.
Eventually I decided to check what was the actual value of OCR1A:
  while(!Serial) {}
  pinMode(9, OUTPUT);
bool firstTime = true;
  if(firstTime) {
    firstTime = false;
     Serial.print("OCR1A "); Serial.println(OCR1A);
    OCR1A = 31;
    Serial.println("===============");
Guess what the output was:
22:36:52.768 -> OCR1A 0
22:36:52.768 -> ===============
22:36:52.768 -> OCR1A 31
I assumed originally that the Arduino core was at fault by nullifying register OCR1A in between setup() and loop(). But @van_der_decken kindly advised that this was done by writing to TCCR1A, thank you! I believe this was not documented in the datasheet.
Additional Serial.prints revealed that it was the write to TCCR1A that zeroed out OCR1A, not the core.
Writing to OCR1A after setting up TCCR1A and TCCR1B resulted in a 125KHz signal on pin 9.
  while(!Serial) {}
  OCR1A = 31;
  pinMode(9, OUTPUT);
  if(firstTime) {
    firstTime = false;
baudrate=115200
Connected to /dev/ttyUSB0! Press CTRL-C to exit.
OCR1A 31
Great finding, thank you!
I must apologize: this was not the core's bug, but rather the Atmel's one. At least they didn't mention that in the datasheet.
Should I change the title or remove the post altogether?
There are several gotchas with the timers due to the double buffering.
Experienced people learned to clear/set the timer control registers TCCR1A and B before making any changes to other timer registers.
