Weird servo gripper behaviour
Hello,
for my current project i need a servo gripper. I have build a strong gripper using some 3d prints and a rc servo from Amazon.
I'm using a Esp32 and a breadboard 5V power supply.
The mechanical system seems to work just fine. However I have problems programming it.
My goals for the gripper:
-grip as hard on the object, object should be of varying size
-return to a "normal" position, which is the open position
Here's a video of it using the code i wrote: https://youtube.com/shorts/QC1ttSWhqTU?feature=share
And here's the code:
#include <ESP32Servo.h>
Servo gripperServo;  // Create a Servo object
const int gripperPin = 25;       // Pin connected to the servo signal wire
const int openAngle = -250;         // Angle to fully open the gripper
const int closeAngle = 10;      // Angle to fully close the gripper
const int holdTime = 2000;       // Time in milliseconds to hold the position
const int minPulseWidth = 500;   // Minimum pulse width in microseconds
const int maxPulseWidth = 2500;  // Maximum pulse width in microseconds
int pos;
// Define min and max pulse widths
  // Attach the servo on pin 13 to the servo object with min and max pulse widths
  gripperServo.attach(gripperPin, minPulseWidth, maxPulseWidth);
  gripperServo.write(0);
  // Open the gripper as far as possible and hold for a few seconds
  gripperServo.write(openAngle);
  delay(holdTime);
  // Close the gripper as far as possible and hold for a few seconds
  gripperServo.write(closeAngle);
  delay(holdTime);
  // Repeat the cycle
Does anyone have an idea on how to tackle my problem and help me?
Thanks
aren't the argument to write() pulse widths from 500 to 2500, not angles
Ok, should i then map the angles to the pulse width?
yes
Thanks to all of you. Yeah, solved the problem. I just had to bring the servo to its 0° position and reassemble the gripper
