Thanks for the reply,
I have been able to diagnose the problem and have been able to solve it.
The culprit seems to be a wrongly placed delay and the following piece of code:
display.clearDisplay();
display.setCursor(0, 0);
display.println(“Accelerometer”);
display.setCursor(0, 15);
display.println(“Sending data”);
display.display();
But I do not understand why this causes an issue(I am new at Arduino and coding).
Could you explain this?
(I have marked the issue causing pieces of the code)
Adapted from MOPU6050_DMP6 by Jeff Rowberg for testing purposes. Find the source
at: https://github.com/jrowberg/i2cdevlib/tree/master/Arduino/MPU6050
#include <WiFi.h>
#include "PubSubClient.h"
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include <Adafruit_SSD1306.h>
MPU6050 mpu;
Adafruit_SSD1306 display = Adafruit_SSD1306(128, 32);
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
Quaternion q; // [w, x, y, z] quaternion container
VectorInt16 aa; // [x, y, z] accel sensor measurements
VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
VectorFloat gravity; // [x, y, z] gravity vector
float euler[3]; // [psi, theta, phi] Euler angle container
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
// Add your MQTT Broker IP address, for example with Mosquitto Broker:
//const char* mqtt_server = "192.168.0.192";
const char* mqtt_server = "test.mosquitto.org";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
const char *ssid = "SSID"; // replace with your wifi ssid and wpa2 key
const char *pass = "wpa2 key";
// === INTERRUPT DETECTION ROUTINE ===
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
mpuInterrupt = true;
delay(10);
Wire.begin(5,4);
Wire.write(0x1A); // write to address 26 of the register
Wire.write(0x04); // options here are 0x00 which is off, and 0x01, 0x02, 0x03, 0x04, 0x05, 0x06
Wire.endTransmission(true); // 0x06 being the highest filter setting
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x32
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
display.display();
delay(500); // Pause for 2 seconds
display.setTextSize(1);
display.setTextColor(WHITE);
display.setRotation(0);
setup_wifi();
client.setServer(mqtt_server, 1883);
mpu.initialize();
devStatus = mpu.dmpInitialize();
mpu.setXGyroOffset(20);// offset for my chip
mpu.setYGyroOffset(-34);// offset for my chip
mpu.setZGyroOffset(13);// offset for my chip
mpu.setXAccelOffset(-1833);// offset for my chip
mpu.setYAccelOffset(1370); // offset for my chip
mpu.setZAccelOffset(1235); // offset for my chip
if (devStatus == 0) {
Serial.println(F("Enabling DMP..."));
mpu.setDMPEnabled(true);
Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
attachInterrupt(0, dmpDataReady, RISING);
mpuIntStatus = mpu.getIntStatus();
Serial.println(F("DMP ready! Waiting for first interrupt..."));
display.println("Waiting for interrupt");
display.display();
dmpReady = true;
packetSize = mpu.dmpGetFIFOPacketSize();
else {
Serial.print(F("DMP Initialization failed (code "));
Serial.print(devStatus);
Serial.println(F(")"));
void setup_wifi() {
Serial.println("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
display.println("WIFI connected");
display.display();
delay(2000);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("ESP8266ClientVindi")) {
Serial.println("connected");
display.setCursor(0,15);
display.println("MQTT connected");
display.display();
delay(2000);
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");// Wait 5 seconds before retrying
display.println("MQTT connection failed");
display.display();
delay(5000);
if (!dmpReady) return;
while (!mpuInterrupt && fifoCount < packetSize) {
fifoCount = mpu.getFIFOCount();
if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
mpu.resetFIFO();
Serial.println(F("FIFO overflow!"));
else if (mpuIntStatus & 0x02) {
while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
mpu.getFIFOBytes(fifoBuffer, packetSize);
fifoCount -= packetSize;
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetAccel(&aa, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetLinearAccel(&aaReal, &aa, &gravity);
mpu.dmpGetLinearAccelInWorld(&aaWorld, &aaReal, &q);
Serial.print(aaWorld.x); //acceleration rotated into the world reference frame
Serial.print("\t");
Serial.print(aaWorld.y);
Serial.print("\t");
Serial.println(aaWorld.z);
delay(25); // This seemed to cause the issue <---------------
if (!client.connected()) {
reconnect();
client.loop();
long now = millis();
if (now - lastMsg > 250) {
lastMsg = now;
client.publish("esp32/XAcc", String(aaWorld.x).c_str(), true);
client.publish("esp32/YAcc", String(aaWorld.y).c_str(), true);
client.publish("esp32/ZAcc", String(aaWorld.z).c_str(), true);
display.clearDisplay(); // This seemed to cause the issue <---------------
display.println("Accelerometer");
display.println("Sending data");
display.display(); // This seemed to cause the issue <---------------
