Hi there,
Still traveling within the first batches of tests with iot, through my wifi 1010 mkr measuring some sensors values.
I noticed another thing weird, the first thing being a question still not solved in another thread where some integer variables gives some float in the arduino cloud widgets... Which is VERY weird.
The new thing is
I'm measuring temperature with a timer in the arduino. Each 1s, it reads the sensor, stores it in the last index position of an array with a size of 60,and do a mean. This current running mean is stored in a float variable, the one updating the cloud.
It is a cheap and easy process to smooth. Working fine in all other cases (of my programmer's life).
Some values, only one sometimes at a time, usually, are like that one.
I could imagine this is a sensing mistake... But come one... Smoothed with a running mean over 60 measures?!
Me too.
I am guessing that the data could have been corrupted.
During the transmission.
Sadly I have no idea how to fix that.
Maybe by passing the data back to the arduino and checking it?
You could use some variables and some if’s to do that.
I currently have no ideas about what is wrong.
Still thinking.
I give you a list of cloud providers soon(1-2 days?). @structurevoid
what do you mean with this?
Sorry haven't had the time to look for cloud services.
It is quite impossible that data gets corrupt during trasmission to the cloud
You need to investigate more about the issue in your algorithm. I recommend you post your code here so that multiple eyes can help spot the issue
This is the first thing I thought & I still think.
I probably messed something.
Here it is, not a secret nor science rocket
#include "thingProperties.h"
#include <math.h>
#if defined(ARDUINO_ARCH_AVR)
#define debug Serial
#elif defined(ARDUINO_ARCH_SAMD) || defined(ARDUINO_ARCH_SAM)
#define debug SerialUSB
#else
#endif
// GROVE TEMPERATURE
const int B = 4275; // B value of the thermistor
const int R0 = 100000; // R0 = 100k
const int pinTempSensor = A0; // Grove - Temperature Sensor connect to A0
float currentTemperature;
// inner timerS
unsigned long previousMillis = 0;
const long interval = 1000; //milliseconds
const int numReadings = 60;
float readings[numReadings]; // the readings from the analog input
int readIndex = 0; // the index of the current reading
float total = 0; // the running total
float average = 0; // the average
delay(1500);
// initialize all the readings to 0
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
initProperties();
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
if (currentMillis - previousMillis >= interval) {
// TEMPERATURE
int a = analogRead(pinTempSensor);
float R = 1023.0 / a - 1.0;
R = R0 * R;
currentTemperature = 1.0 / (log(R / R0) / B + 1 / 298.15) - 273.15; // convert to temperature via datasheet
// subtract the last reading:
total = total - readings[readIndex];
// read from the sensor:
readings[readIndex] = currentTemperature;
// add the reading to the total:
total = total + readings[readIndex];
// advance to the next position in the array:
readIndex = readIndex + 1;
if (readIndex >= numReadings) {
readIndex = 0;
// calculate the average:
temperature = total / numReadings;
I was suspecting something about unsynced timer.
My measure in the loop VS the cloud update. I asked something in another post about this.
But I can't imagine this.
Things happening sequentially here.
So the loop : cloud update, measure, mean calculation, variable updated.
Etc etc.
Couldn't be that.
But if I can't have more informations about this, I should find another cloud/system for sure.
Actually, I'd like to keep it but to store values in a Google sheets too. Just for comparing. Maybe.
Have you tried to log a variable with a simpler logic? For example i have an uptime counter incrementing each second and i'm logging the values in a chart like you do. The line in smooth without any artifact or spike.
At first, I fixed something in my code.
The mean was always considering that 60 values were already measured. It was missing one case: the first 60 measures.
Ok.
Indeed, I was suspecting some reboots.
And in that case, the first 59 measures would have been unconsistent.
here is the new one for the record, and those interested:
// STRUCTURE VOID
temperature
- 1 samp pers second
- running mean calculation considering the latest 60 measures
- handling the case of the first 59 measures
#include <math.h>
#else
#endif
// inner timerS
int alreadyStored = 0;
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// initialize all the readings to 0:
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
upt = millis() / 1000;
// TEMPERATURE
R = R0 * R;
//Serial.println(temperature);
// if we're at the end of the array...
// ...wrap around to the beginning:
readIndex = 0;
if (alreadyStored< numReadings) alreadyStored++;
temperature = total / alreadyStored;
Ok but it doesn't explain the "only one value bad" issue.
So I suspect something.
If the hardware were rebooting, how the cloud update routine would behave ???
Things seem okay since yesterday update.
It has fixed the thing but I didn't identify the cause.
For the record.
Data were totally OK in the board, the adaptative recurring mean working fine. And even before the last update, it should have been ok.
The only thing that could have happened, on my opinion, was a kind of auto reboot/reset.
Thought about a kind of watchdog issue.
But the arduino cloud update reset the watchdog. And actually, I don't like the idea to disable it.
No electricity fault. And my two different boards with same code were running in... Two different places and issues were rye same.
