I'm reading pressure from a SCUBA cylinder, which is gradually emptying as I change and discharge it .. so all my readings differ over time
But right now,
ADS is reading 2.594V
Voltage across the 200 ohm resistor is 2.51V
Voltage at the ADS input pin fluctuates while is connected, but if I disconnect just the ADS input, it also reads 2.51 (ie, across both the 200 ohm and 10k resistors)
The 10k is there from the suggestion in this post:
Current as measured with multimeter is 12.53mA
