well I have amassed enough cool stuff...lets build something! Code help please.
Hello, happy new year! (Suck it Mayans! :D) I am new-ish to the Arduino thing, but I am hooked! I am damn near a Electronics Engineer (1&1/2 quarters left for my associates) so I should be able to keep up (I hope). I really enjoyed my class on C programming, and the Arduino language seems similar, but I still currently suck at it! :blush: SO, I have got the following items together, and I would like to build a small RC rover, just to lean some of the ropes for one. Here is what I am working with:
  1. A adjustable step down to supply the correct Vin to the Arduino.
    Power Regulators & Converters for sale | eBay
  2. A Arduino UNO (I have a MEGA and Mini too if they would work better, but I was going to use the UNO)
  3. motor driver shield.
    http://www.ebay.com/itm/261074724224?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
  4. A duel motor gearbox.
    Dual Motor GearBox - ROB-00319 - SparkFun Electronics
  5. A transmitter and receiver.
    http://www.ebay.com/itm/121000399490?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
  6. Two wheels and tires from an old RC truck.
  7. One swivel caster.
  8. Determination.
I am good with hardware, just tell me how to wire it, and it will be done correctly (soldering too), but I need help with the code for sure. I AM trying to learn it, but for now, a little help to get this first one under my belt would be greatly appreciated. :smiley: Thanks, Steve!
You're missing 9: a clear idea of what you want it to do.
...... I want to build a toaster! :stuck_out_tongue_closed_eyes:.("RC rover").....
Thanks for the reply anyway Pete, karma given, any help would be great! Steve
If it helps inspire you, here is my project about a RC vehicle:
Various issues are discussed on that page, so you can pull out whatever seems relevant (if anything).
Thanks!
Cool project and I like the 'body work' your kids most likely came up with. A technical issue I came up with on first reading is on low battery detection:
So, a method of detecting low voltage was necessary. Since the car was powered by a Li-Po battery (two cells in series) its valid range was 7.4V to 8.4V. Now 8.4V is too much to plug into an analog port, so we need to get it down to the range 0 to 5V. Thus, a simple voltage divider will do it:
Typically a Li-Po cell is consider fully charged at 4.2vdc and most use a 3.0 value for low cut-off value. So your 2X cell should be using 6 to 8.4 as usable range and so you are not utilizing a whole lot of your pack by using a 7.4 cut off value.
Lefty
You could also have a look around rcarduino.blogspot.com
Duane B
retrolefty:
Er, yes, absolutely. My kids did that bit. Please don't show them this page.
Thanks for the comments. I was being cautious after reading about fires and stuff.
Batteries are one of those things where you can read a dozen sites and get all sorts of advice, not always totally in agreement.
Arduino420:
Yes, but what do you want the rover to DO?
If you don't want it to do anything then you can just pile the hardware into a box and put it in the middle of the floor and call it a rover.
I guess you want it to move backwards and forwards and steer, but you haven't defined that at all. Will it be completely autonomous? If so, will it need to sense its surroundings (how?) and what will it do in response to them? Will it be remotely controlled? If so, what communication mechanism will you use and what sort of input device for the operator to enter the commands? What sort of commands do you want it to recognise? Will it just a matter of holding a switch down to make it move forward and let go to stop, or something more sophisticated like "mow the lawn" and "go tidy your room"?
Wasn't that obvious? It needs to make toast. 8)
PaulS:
OK sorry about that. I was doing some drunken (non specific) posting last night.
To start with I just want to use the left stick on the transmitter (and receiver) that I posted a link to in my original post to do forward (up), reverse (down), left would signal the right motor to go forward and the left motor to go back, right would trigger the left motor to go forwards and the right motor to go back. That would do fine for now. After I get that going I have a robotic claw that I would like to control with the right stick, but that will come later. also toast is optional.... How should I wire up the duel motor gear box that I posted a link to? I have it assembled, and I have tested both motors. Thanks a lot for any help! Steve
Also!...... I have been told by the Super nerds on the Robosavvy forum that what I am trying to build is NOT a "Robot", it is a "Wheeled rover platform for Electronics"! That has a nice ring to it huh!?? :stuck_out_tongue:
Two channel RC Transmitter to tank tracked chassis with low speed turning on the spot, high speed radius turns (I may have made that term up, but at low speed the tracks counter rotate, at higher speeds, the tracks rotate in the same direction but at different speed) -
I am sure your motor control is different but the concept will be the same.
Duane B
Thanks! Karma for you sir! Steve
PaulS:
Are you insane? You need it to (1) deliver a cold beer to your hands, without your having to move from your chair. And then 15 minutes later: goto 1. (oops, used goto).
Rewording without using goto:
while (owner_is_sober)
  deliver_beer ();
I hope that deliver_beer() has some affect on owner_is_sober. Otherwise, that's an infinite loop. Not that that's all bad... 8)
