I bought an arduino mega 2560 and wired it so I have one servo and one motor. they both work but i am trying to write a program where i can control the motor with key 1 and the servo with keys 8,9,0. when i hold any button down it turns the servo one way. I had a motor shield but i took it off because it was complicating things. here is my code. could you please help. thanks.
#include <Servo.h>
int motorf = 9;
Servo myservo;
int pos = 0;
myservo.attach(7);
pinMode(motorf, OUTPUT);
while (Serial.available() == 0);
int val = Serial.read() - '0';
int i = myservo.read();
if (val == 1) ;
digitalWrite(motorf, HIGH);
delay(1);
digitalWrite(motorf, LOW);
delay(1);
This is meaningless.
A for loop needs a start, an end and an increment - there is no end in this.
Also the final semicolon means it does nothing anyway.
If you mean to increase the position by 1 every time the button is detected all you need is
pos += 1;
But you will also need code to prevent pos exceeding 180 or whatever max you want to enforce.
Holding down a PC key to cause repeated action on an Arduino would be much better done with a PC program (perhaps written in Python) which sends a start character when the key pressed and a stop character when the key is released.
...R
And if you put your code in code tags as I have done you won't have silly smileys in it.
thanks, I got the servo to turn and go back to pos 0 when i press 8,9,0 but it only turns one way. also i decided to add the motor shield after all and i adjusted my program to it. although the motor still won't go. its a seed studio motor shield 2.o, sorry for not adding code tags
#include <Servo.h>
int motorf = 9;
int motorb = 10;
Servo myservo;
int pos = 0;
myservo.attach(7);
pinMode(motorb, OUTPUT);
if (val == 1)
delay(1);
delay(1);
if (val == 2)
digitalWrite(motorb, HIGH);
delay(1);
digitalWrite(motorb, LOW);
delay(1);
In Reply #3 I suggested using a PC program to send data to the Arduino when a PC key is pressed or released and I suggested that such a program could be written in Python. It could also be written in any other PC language.
