Hi Folks,
I'm testing the following code which is nothing more than a slight variation on the AnalogRead code. I added the while loop which I also tried as a for loop with the same results... my tone does not stop and my serial monitor freezes. Any thoughts?
int pinSpeaker = 11;
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
pinMode(pinSpeaker, OUTPUT); //declare speaker as output
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
Serial.println(voltage);
while (voltage > 0){
tone(pinSpeaker, 500, 200);
Thanks in advance!
