What does "collect2.exe: error: ld returned 1 exit status" mean?
I am in a robotics class and we are working with Arduino Uno R3 boards with Adafruit motors shields. We are trying to use encoders to calibrate the power of slave motors based on master motor rotation, but I cannot upload to the board because of the following error:
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\KSCHUT~1\AppData\Local\Temp\ccQRXTjR.ltrans0.ltrans.o: In function `main':
C:\Users\kschutt19\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino/main.cpp:46: undefined reference to `loop'
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
Also, nothing has been highlighted in the code as an error.
-I have reinstalled the Arduino IDE on my computer
-I have reset my board
-I have tried a different USB cable
-I have tried uploading to a different board on another robot
-I have copied/pasted the code and emailed it to another computer, then tried to download to my board
Here is the code:
#include <Adafruit_MotorShield.h>
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
int LEncoder = 4;
int REncoder = 3;
int RCount = 0;
int LCount = 0;
int pastLeft = 0;
int pastRight = 0;
int currentLeft = 0;
int currentRight = 0;
int masterPower = 30;
int slavePower = 30;
int error = 0;
int kp = 1;
int drive = 100;
Adafruit_DCMotor *myMotor1 = AFMS.getMotor(1);
Adafruit_DCMotor *myMotor2 = AFMS.getMotor(2);
Adafruit_DCMotor *myMotor3 = AFMS.getMotor(3); //back left is M3
Adafruit_DCMotor *myMotor4 = AFMS.getMotor(4);
  AFMS.begin();
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  delay(2000);
while (LCount <= drive && RCount <= drive){
  myMotor1->setSpeed(masterPower);
  myMotor2->setSpeed(slavePower);
  myMotor3->setSpeed(slavePower);
  myMotor4->setSpeed(masterPower);
  myMotor1->run(FORWARD);
  myMotor2->run(FORWARD);
  myMotor3->run(FORWARD);
  myMotor4->run(FORWARD);
  currentLeft = digitalRead(LEncoder);
  currentRight = digitalRead(REncoder);
//0 = blocked
  if (pastLeft == 1 && currentLeft == 0){
    pastLeft = 0;
  else if (pastLeft == 0 && currentLeft == 1){
    pastLeft = 1;
    LCount = LCount +1;
  else if (pastRight == 1 && currentRight == 0){
    pastRight = 0;
  else if (pastRight == 0 && currentRight == 1){
    pastRight = 1;
    RCount = RCount +1;
  error = LCount - RCount;
  slavePower += error / kp;
  delay(100);
  myMotor1->run(RELEASE);
  myMotor2->run(RELEASE);
  myMotor3->run(RELEASE);
  myMotor4->run(RELEASE);
Thank you for any helpful tips!
(deleted)
Code is not a valid arduino sketch. You must define a setup() and loop() function - even if loop() is empty, it has to exist.
What it means is that you started at the wrong end of the list of messages. Start with the FIRST message, and resolve that issue. Forget about focusing on the last message. That one will go away when you have fixed the others.
FYI
I have a project that compiles in the Arduino 1.8.4
but when I try it in the Arduino IDE Arduino 1.8.12 (windows store 1.8.33.0)
it too shows the same error.
I tracked it down to the area WiFiClient / WiFiServer elements
So that's code you haven't posted and "same error" that you haven't posted. I can't see anything to help with there, sorry.
Steve
