Installing SAM notes
Do you really need a detailed note on what each site says.
Ok, you do, start with:
https://www.arduino.cc/en/Guide/ArduinoDue#toc3
This is one of the leading returns from a search for the phrase: arduino due tutorial
On that page is this text
• Use your Arduino Due on the Arduino Web IDE
• Use your Arduino Due on the Arduino Desktop IDE
o Installing the Arduino Sam Boards core
o Installing Drivers for the Due
Click on the link: Installing the Arduino Sam Boards core
There are instructions for OSX and Windows XP and 7. So this is quite old, but it is a first level return for that search.
It instructs the read to install the Arduion IDE. Which I already have. The link specifically stated install the Sam Boards core, nothing about the IDE.
Search the text for “sam” No further occurences until the tutorial gets to the Linux section. Check each of the 17 occurrences of “sam”. None of them describe a SAM package to install.
That was not fruitful.
To the first reply from pert.
SAM is the architecture of the microcontroller used on the Arduino Due.
That agrees with the printing on the CPU chip. That does not describe an installation package that fits the words: Installing the Arduino Sam Boards core.
The text of link in that web page is:
The post does not answer the question: What is this thing to install referred to by the phrase Sam Boards core?
Moving on to the next phase of the reply where it instructs:
Evidently so. Here are some detailed instructions:
Tools > Board > Boards Manager
Wait for the download to finish.
Mine is a bit different:
Tools -> Board: “Arduino Due (Programming Port)” -> Board Manager
Selecting that option produces a long list of options, none of which contains “SAM”, or “Sam” or “sam”.
At the bottom is a selected bullet with the text Arduino Due (Programming Port)
Mouse down to that and click it, nothing. No download is initiated. I will upload a screen capture of that menu.
In conclusion: What is this thing called SAM that is to be installed?
Yes, I see that the architecture of the CPU is apparently SAM, but what is the software package to download and install. What does it do?
