For anyone wondering the motor works (I can power an LED by spinning the shaft).
So I tried using a 9V battery and I checked and it only draws something like 0.1 mA. Not enough for a motor that can go up to even 1.6A (checked on the datasheet).
So what power source am I supposed to use for my project? In particular what battery should I be using?
Use a DRV8825 stepper motor driver with that motor. Use a power supply that can provide anywhere between 12v and 36v (higher is better) with an output of 2 amps (or more). Be sure to set the current limit on the stepper driver so as to protect the motor.
Stepper motors are very inefficient and are not suited to battery power. If you must use a battery get a rechargeable one that can provide at least 12v and which has a capacity of at least 5 amp hours.
Robin2:
roxingby:
Hey I am using a A4988 as the driver, would it still be fine?
An A4988 will struggle to provide the 1.68 amps required by your motor. If it overloads it will cut out and you will miss steps. You could set it at 1.5 amps and maybe there would still be enough motor torque.
A heat sink and cooling fan for the A4988 chip would help.
Robin2:
...R
Yeah I already put the heat sink on it, it can hold up to 2 amps with it
The general consensus on this Forum is that the A4988 cannot provide that current continuously. That's why I suggested setting the current limit at 1.5 amps and, earlier, suggested using a DRV8825.
