So basically i want to log temperature and time in arrays so i can send them via webserver to the clients when connecting. storing them "in the opposite way" (0 = latest and x = oldest) so i can loop the array backwards to send the data in the right order.
The temperature array using floats works perfectly.
The time array for minute and second is chewing on my esp somehow.
heres the code:
float storedtemps[3];
int storedminutes[3];
int storedseconds[maxstoredvalues];
void gettime(){
for(int i = maxstoredvalues; i >= 0; i--){
struct tm timeinfo;
getLocalTime(&timeinfo);
byte minutes = timeinfo.tm_min;
byte seconds = timeinfo.tm_sec;
if(i != 0){
storedseconds[i] = storedseconds[i-1];
storedminutes[i] = storedminutes[i-1];
}else{
storedseconds[0] = seconds;
storedminutes[0] = minutes;
void getTemperatureandlog(){
sensors.requestTemperatures();
float temperature = sensors.getTempCByIndex(0);
if(i != 0){
storedtemps[i] = storedtemps[i-1];
}else{
storedtemps[0] = temperature;
The Print Function:
void printarraycontents(){
Serial.println("-----------NEW LOG----------");
for(int i = 0; i <= maxstoredvalues; i++){
Serial.print("Index : ");
Serial.print(i);
Serial.print(" ");
Serial.print(storedminutes[i]);
Serial.print(":");
Serial.print(storedseconds[i]);
Serial.print(" value : ");
Serial.println(storedtemps[i]);
Result:
The red (should be only right) is the seconds readings.
The blue ( should be only left) is the minute readings.
I dont know how that is even possible.
Side Note:
When changing the array types of time to "byte" instead of "int" the temperature readings in the "value" section are showing up again.
Part of the error occurs in the rest of the sketch that you did not show. Snippets are not useful.
Pretty sure the rest wont help, however here it is:
(yes i removed the wlan credentials)
#include <OneWire.h>
#include <DallasTemperature.h>
#include <WiFi.h>
#include "esp_sntp.h"
#include "time.h"
OneWire oneWire(4);
DallasTemperature sensors(&oneWire);
const int maxstoredvalues = 2; //(wanted -1)
float storedtemps[maxstoredvalues];
byte storedhours[maxstoredvalues];
byte storedminutes[maxstoredvalues];
byte storedseconds[maxstoredvalues];
char * ssid = "i";
char * password = "";
WiFi.begin(ssid,password);
while(WiFi.status()!=WL_CONNECTED){
Serial.print(".");
sensors.begin();
//Time Client
esp_sntp_servermode_dhcp(1);
configTime(3600, 0, "pool.ntp.org", "time.nist.gov");
getTemperatureandlog();
gettime();
delay(2500);
printarraycontents();
void gettime(){
struct tm timeinfo;
if(i != 0){
}else{
if(i != 0){
}else{
Serial.print(i);
Serial.print(" ");
Serial.print(":");
Overruns storedseconds. That would be undefined behaviour.
And you are wrong, again.
Now that we can see how maxstoredvalues is defined and used to declare arrays, the cause of the error identified by @Coding_Badly is self evident.
The guideline against using snippets exists for a very good reason, as illustrated in this topic.
This works in the "gettime" function flawlessly tho. and it starts at the last index and stops at 0. not sure how it would overrun, it also exits the loop
tried it with defining it seperatly, doesnt make any difference.
Very well. It's no problem to me if you don't want to correct a very elementary mistake.
LarryD
March 15, 2025, 11:16pm
9
I cannot stand code that is not formatted !
#include <WiFi.h>
#include "time.h"
OneWire oneWire(4);
char * ssid = "i";
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
sensors.begin();
//Time Client
gettime();
delay(2500);
void gettime()
struct tm timeinfo;
for (int i = maxstoredvalues; i >= 0; i--)
if (i != 0)
storedseconds[i] = storedseconds[i - 1];
storedminutes[i] = storedminutes[i - 1];
if (i != 0)
storedtemps[i] = storedtemps[i - 1];
for (int i = 0; i <= maxstoredvalues; i++)
Serial.print(i);
Serial.print(" ");
Serial.print(":");
Which makes it even more evident that your complete sketch is nescessary to analyse what the error is as the error still occurs.
Your initial code-snippet did NOT show
it only hsowed this
Your loop runs from
maxstoredvalues which is 2
down to i >= 0
which means i runs down to 0
and what you calculate here
storedseconds[i-1]
is 0 -1 = -1
though index MINUS 1 does not exist
You copied half the code there, or am i this tired?
if(i != 0){
}else{
only calculates it when its not 0, when its 0 itll use the value that it got from the beginning
not sure if i understand you correctly, your saying i shouldnt use a variable to set the length of an array?
#include <WiFi.h>
#include "time.h"
OneWire oneWire(4);
const int maxstoredvalues = 4; //(wanted -1)
float storedtemps[4];
byte storedhours[4];
byte storedminutes[4];
byte storedseconds[4];
char * ssid = "";
Serial.print(".");
sensors.begin();
//Time Client
gettime();
delay(2500);
void gettime(){
struct tm timeinfo;
if(i != 0){
}else{
if(i != 0){
}else{
Serial.print(i);
Serial.print(" ");
Serial.print(":");
Result:
Time Was: 00:25, format here is minute:second
If you define an array like this
means you have arrays with 2 elements
element with index 0
element with index 1
then you run a for-loop
But you try to access element with index 2
which does not exist because a 2 elements array has only index 0 and index 1
The graphic that you posted
seems to have 4 elements
starting at 0 going up to 3
So all in all always post your complete and most actual sketch that fits to the serial output that you use to explain the problem
info: i may have changed the array sizes between posts
i was not aware setting it differently would actually change the size of the array.
When using:
Expected: Array With 5 values from 0 to 4.
Result:
When using a const variable for it (i expected to be exactly the same)
Result:
funny thing is, when i change the array types to int(of the time arrays), it breaks the entire temperature array(the seperate float array) and it just reads 0 in the print.
wait, am i tripping? defining an array with
int array[2];
would have 3 members, wouldnt it?
-Index 0
-Index 1
-Index 2
no only 2 elements
element 1: Index 0
element 2: Index 1
how am i getting 5 different temperature readings on the right?
and with the index aswell.
does is differ when using float arrays or int arrays?
LarryD
March 16, 2025, 12:05am
18
Your code says so.
4, 3, 2, 1, 0
for(int i = maxstoredvalues - 1 ; i >= 0; i--){
tried printing the array's position isnt shouldnt even have:
the value/temperature works as expected.
but the time... i really dont know whats going on there
You are breaking the rules and accessing memory that you have no right to access. Sometimes that works, other times it will crash the computer.
Why bother to post if you can't accept elementary advice, from people who do understand these points?
