What's wrong with my keypad and time program?
I'm a total noob in Arduino and this is my first Arduino project. I've been trying to get the keypad to be able to input time for my alarm clock project but I only managed to get the welcome part of the program. But then the display stuck at the welcome part only. I want to set alarm time by using the keypad only, and if the alarm time is the same as the time display, the buzzer should ring.
I'm positive that there's no problem with hardware since all of the components (16x2 LCD, RTC DS1307, buzzer, 4x4 keypad) work properly when I use some basic tutorial coding for the components.
Please check what could be wrong in my code? I've tried to replace some of the codes but it had no change; the display's still stuck at the welcome part. If there's any update on what I've edit to my code later, I will edit this question's body. Thank you in advance.
#include <EEPROM.h>
#include <Keypad.h>
#include <DS1307.h>
#include <Wire.h>
#include <LiquidCrystal.h>
DS1307 rtc(SDA, SCL);
LiquidCrystal lcd(A3, A2, A1, A0, 5, 4);
Time t;
#define buz 3
int Hor, Min, Sec, h, m, s;
int ASCII = 48;
char* tim;
char* dat;
char buffer[3];
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[ROWS] = {6, 7, 8, 9};
byte colPins[COLS]= {10, 11, 12, 13};
Keypad keypad= Keypad(makeKeymap(keys),rowPins, colPins, ROWS, COLS);
Wire.begin();
rtc.begin();
pinMode(buz, OUTPUT);
lcd.begin(16, 2);
welcome();
rtc.setDOW(TUESDAY); //Set Day-of-Week to SUNDAY
rtc.setTime(18, 20, 00); //Set the time to 12:00:00     (24hr format)
rtc.setDate(18, 12, 2018); //Day, Month, Year
t = rtc.getTime();
Hor = t.hour;
Min = t.min;
Sec = t.sec;
tim = rtc.getTimeStr();
dat = rtc.getDateStr();
char key = keypad.getKey();
if(key == 'A'){
alarm();
if (key == 'C'){
digitalWrite(buz, LOW);
EEPROM.write(2, ASCII+6);
EEPROM.write(3, ASCII);
changealarm();
checkalarm();
timedate();
void checkalarm(){
if( Hor == h && Min == m)
delay(3000);
lcd.setCursor(0,1);
lcd.print("Hold C");
digitalWrite(buz, HIGH);
delay(3000);
void changealarm(){
buffer[2] = 0;
buffer[0] = EEPROM.read(0);
buffer[1] = EEPROM.read(1);
h = atoi(buffer);
buffer[0] = EEPROM.read(2);
buffer[1] = EEPROM.read(3);
m = atoi(buffer);
buffer[0] = EEPROM.read(4);
buffer[1] = EEPROM.read(5);
s = atoi(buffer);
void timedate(){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Date: ");
lcd.print(rtc.getDateStr());
lcd.setCursor(0,1);
lcd.print("Time: ");
lcd.print(rtc.getTimeStr());
delay(3000);
lcd.setCursor(0,1);
lcd.print("Alarm: ");
lcd.print(h);
lcd.print(":");
lcd.print(m);
lcd.print(":");
lcd.print(s);
delay(3000);
void welcome(){
lcd.setCursor(0,0);
lcd.print("Welcome");
lcd.setCursor(0,1);
lcd.print("To");
delay(2000);
lcd.setCursor(0,1);
lcd.print("TIMe Project");
delay(2000);
void alarm()
int j=0;
lcd.clear();
lcd.print("Enter Alarm Time: ");
lcd.setCursor(0,1);
while(j<4)
lcd.print(h);
lcd.print(":");
lcd.print(key);
lcd.print(m);
lcd.print(":");
lcd.print(key);
lcd.print(s);
lcd.print(key);
key=0;
Show us a good schematic & image of your circuit.
Posting images:
http://forum.arduino.cc/index.php?topic=519037.0
Hudhudpanda:
Plus, the deadline is in two days.
Whining about that and claiming that your problem is “Urgent” probably won’t have the desired outcoming of motivating people to help you. In fact, it could have the opposite effect.
...and repeating a post in a different part of the forum is a pretty useful way of getting a forum timeout.
Duplicate deleted - do NOT repeat.
I don't know if this is the problem, but once your code gets to this function, j never changes from 0 so the while loop lasts forever.
void alarm()
int j=0;
lcd.clear();
lcd.setCursor(0,1);
while(j<4)
lcd.print(h);
lcd.print(":");
lcd.print(key);
lcd.print(m);
lcd.print(":");
lcd.print(key);
lcd.print(s);
lcd.print(key);
key=0;
Also there's a LOT of delay() commands in your sketch. They will cause it to be unresponsive for a lot of the time.
Thank you for the feedbacks. I appreciate it. It's my bad since I'm being too pushy. I've edited the question to be less 'pushy'. Regarding the alarm() part, I'll try my best to change it to what ever I can do. And yes, I've noticed that the delays are disturbing the flow of the program. Thank you for pointing it out.
And remember in while(j<4) j does not change.
