Hello all forum's member,
I would like to ask, what's wrong with this code?
#include <Servo.h>
// Two motors, a servo, and an IR range sensor.
Servo sensorServo, centerServo;
const int irPin = A0; // analog pin 0
// Timing. I don't like using delay.
unsigned long tCnt = 0;
unsigned long tStart = 0;
unsigned long tDelta = 0;
unsigned long tTurn = 0;
unsigned long tTurnDur = 400; //turn duration
int state; // Current Robot State
int lastState; // Previous Robot State
int servoPos; // Position to send servo
int centerPos; // Center position to send servo
int servoDirection; // Direction servo is turning
int lastDetectionAngle; // Position of servo at last IR detect.
int sensorValue = 0; // sensor value
const int minDistance = 20; // minimum distance 20 cm
// Constants for state of robot wheel
const int STATE_FORWARD = 1;
const int STATE_TURN_RIGHT = 2;
const int STATE_BACKWARD = 3;
const int STATE_TURN_LEFT = 4;
// Constants for Servo.
const int DIR_LEFT = 0;
const int DIR_RIGHT = 1;
const int MIN_DEGREE = 40;
const int MAX_DEGREE = 140;
// Constants for robot wheel.
const int RIGHTSPEED = 255; //right motor speed
const int LEFTSPEED = 255; //left motor speed
int motorR = 5; //right motor
int dirmotorR = 4; //motor direction
int motorL = 6; //left motor
int dirmotorL = 7; //motor direction
// Using Ultrasonic Range Sensor HC-SR04
#include <NewPing.h>
#define TRIGGER_PIN 2 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN 3 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
* Initializes everything. Is run once.
Serial.begin(9600); // set up Serial library at 9600 bps
sensorServo.attach(9); // attaches the servo on pin 9
centerServo.attach(10); // attaches the servo on pin 10
tStart = millis();
lastState = state = STATE_FORWARD;
servoPos = 90;
centerPos = 90;
servoDirection = DIR_RIGHT;
sensorServo.write(servoPos);
//state = 0; // Uncomment to have robot not move wheel.
* Runs continuously.
* 1. Update Servo.
* 2. Check IR range sensor.
* 3. Move Robot
tDelta = millis() - tStart;
tCnt += tDelta;
tStart += tDelta;
// Tell the servo to move 2 degrees every 25 ticks.
if( tCnt > 25 ) {
tCnt = 0;
if( servoDirection == DIR_LEFT ) {
servoPos -= 2;
} else if( servoDirection == DIR_RIGHT) {
servoPos += 2;
// Servo position will be beyond desired angles, turn around.
if( servoPos >= MAX_DEGREE ) {
servoDirection = DIR_LEFT;
} else if( servoPos <= MIN_DEGREE ) {
centerServo.write(centerPos);
// Allows disabling of tracks by setting state to 0.
if(state == 0) {
moveRobot();
return;
// sensorValue = read_gp2d12_range(irPin); //uncomment this line if using Sharp GP2D12
int sensorValue = sonar.ping_cm(); // Send out the ping, get the results in centimeters.
delay(25);
if (sensorValue <= minDistance && sensorValue > 0) {
lastDetectionAngle = servoPos;
state = STATE_BACKWARD;
if( state == STATE_BACKWARD ) {
if( lastDetectionAngle > 105 ) { // right
state = STATE_TURN_LEFT;
tTurn = tTurnDur;
} else if( lastDetectionAngle < 75 ) { // left
state = STATE_TURN_RIGHT;
tTurn = tTurnDur;
} else { // center
state = STATE_TURN_RIGHT; // for now, turn right by default.
tTurn = tTurnDur;
} else if ( state == STATE_TURN_RIGHT || state == STATE_TURN_LEFT ) {
if (tTurn > tDelta) {
tTurn -= tDelta;
if( tTurn <= 10 || tTurn < tDelta ) {
moveRobot();
* Uses the state of the robot to move wheels accordingly
void moveRobot() {
// The motors seemed to respond better if they receive a stop before a switch in direction.
if( state != lastState ) {
RMotor(0,false); //stopped
LMotor(0,false); //stopped
switch( state ) {
default:
return; // helps test, state 0 = dont move.
case STATE_FORWARD: {
RMotor(RIGHTSPEED,true); // turn it on going forward
LMotor(LEFTSPEED,true); // turn it on going forward
case STATE_BACKWARD: {
RMotor(RIGHTSPEED,false); // turn it on going backward
LMotor(LEFTSPEED,false); // turn it on going backward
case STATE_TURN_RIGHT: {
RMotor(RIGHTSPEED,false); // turn it on going right
LMotor(LEFTSPEED,true); // turn it on going right
case STATE_TURN_LEFT: {
RMotor(RIGHTSPEED,true); // turn it on going left
LMotor(LEFTSPEED,false); // turn it on going left
lastState = state;
// right motor
void RMotor(int pwmspeed, boolean forward) {
analogWrite(motorR, pwmspeed);
if (forward) {
digitalWrite(dirmotorR, HIGH);
else {
digitalWrite(dirmotorR, LOW);
//left motor
void LMotor(int pwmspeed, boolean forward) {
analogWrite(motorL, pwmspeed);
if (forward) {
digitalWrite(dirmotorL, HIGH);
else {
digitalWrite(dirmotorL, LOW);
// Sharp GP2D12 read distance function
// Uncomment the code below if using Sharp GP2D12 for range sensor
/*float read_gp2d12_range(byte pin)
int tmp;
tmp = analogRead(pin);
if (tmp < 3)
return -1; // invalid value
return (6787.0 /((float)tmp - 3.0)) - 4.0; // output in cm
/* EOF */
I have project to build robot has capability run avoid restriction. my problem, the robot only run backward whereas no restriction in front of the robot. please help me....
