Where do I insert a buzzer code?
Hi! I don't know anything about coding and I'm only trying to put together codes to make my project. I am making a heart rate and pulse oximeter sensor using arduino mega 2560 and found this code online, which worked perfectly with a few adjustments, but I want to add a buzzer module. Where do I insert the buzzer code? I am very clueless and just started with Arduino projects this year for school. Please be kind. Thank you so much!
#include "ssd1306h.h"
#include "MAX30105.h"
#include "Pulse.h"
#include <avr/pgmspace.h>
#include <EEPROM.h>
#include <avr/sleep.h>
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
SSD1306 oled;
MAX30105 sensor;
Pulse pulseIR;
Pulse pulseRed;
MAFilter bpm;
#define LED LED_BUILTIN
#define BUTTON 3
#define OPTIONS 7
static const uint8_t heart_bits[] PROGMEM = { 0x00, 0x00, 0x38, 0x38, 0x7c, 0x7c, 0xfe, 0xfe, 0xfe, 0xff,
                                        0xfe, 0xff, 0xfc, 0x7f, 0xf8, 0x3f, 0xf0, 0x1f, 0xe0, 0x0f,
                                        0xc0, 0x07, 0x80, 0x03, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00,
                                        0x00, 0x00 };
//spo2_table is approximated as  -45.060*ratioAverage* ratioAverage + 30.354 *ratioAverage + 94.845 ;
const uint8_t spo2_table[184] PROGMEM =
        { 95, 95, 95, 96, 96, 96, 97, 97, 97, 97, 97, 98, 98, 98, 98, 98, 99, 99, 99, 99,
          99, 99, 99, 99, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100,
          100, 100, 100, 100, 99, 99, 99, 99, 99, 99, 99, 99, 98, 98, 98, 98, 98, 98, 97, 97,
          97, 97, 96, 96, 96, 96, 95, 95, 95, 94, 94, 94, 93, 93, 93, 92, 92, 92, 91, 91,
          90, 90, 89, 89, 89, 88, 88, 87, 87, 86, 86, 85, 85, 84, 84, 83, 82, 82, 81, 81,
          80, 80, 79, 78, 78, 77, 76, 76, 75, 74, 74, 73, 72, 72, 71, 70, 69, 69, 68, 67,
          66, 66, 65, 64, 63, 62, 62, 61, 60, 59, 58, 57, 56, 56, 55, 54, 53, 52, 51, 50,
          49, 48, 47, 46, 45, 44, 43, 42, 41, 40, 39, 38, 37, 36, 35, 34, 33, 31, 30, 29,
          28, 27, 26, 25, 23, 22, 21, 20, 19, 17, 16, 15, 14, 12, 11, 10, 9, 7, 6, 5,
          3, 2, 1 } ;
int getVCC() {
  //reads internal 1V1 reference against VCC
  #if defined(__AVR_ATmega1284P__)
    ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);  // For ATmega1284
  #else
    ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);  // For ATmega328
  #endif
  delay(2); // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Convert
  while (bit_is_set(ADCSRA, ADSC));
  uint8_t low = ADCL;
  unsigned int val = (ADCH << 8) | low;
  //discard previous result
  low = ADCL;
  return (((long)1024 * 1100) / val)/100;
void print_digit(int x, int y, long val, char c=' ', uint8_t field = 3,const int BIG = 2)
    uint8_t ff = field;
    do {
        char ch = (val!=0) ? val%10+'0': c;
        oled.drawChar( x+BIG*(ff-1)*6, y, ch, BIG);
        val = val/10;
        --ff;
    } while (ff>0);
 *   Record, scale  and display PPG Wavefoem
const uint8_t MAXWAVE = 72;
class Waveform {
  public:
    Waveform(void) {wavep = 0;}
      void record(int waveval) {
        waveval = waveval/8;         // scale to fit in byte  缩放以适合字节
        waveval += 128;              //shift so entired waveform is +ve
        waveval = waveval<0? 0 : waveval;
        waveform[wavep] = (uint8_t) (waveval>255)?255:waveval;
        wavep = (wavep+1) % MAXWAVE;
      void scale() {
        uint8_t maxw = 0;
        uint8_t minw = 255;
        for (int i=0; i<MAXWAVE; i++) {
          maxw = waveform[i]>maxw?waveform[i]:maxw;
          minw = waveform[i]<minw?waveform[i]:minw;
        uint8_t scale8 = (maxw-minw)/4 + 1;  //scale * 8 to preserve precision
        uint8_t index = wavep;
          disp_wave[i] = 31-((uint16_t)(waveform[index]-minw)*8)/scale8;
          index = (index + 1) % MAXWAVE;
void draw(uint8_t X) {
    uint8_t y = disp_wave[i];
    oled.drawPixel(X+i, y);
    if (i<MAXWAVE-1) {
      uint8_t nexty = disp_wave[i+1];
      if (nexty>y) {
        for (uint8_t iy = y+1; iy<nexty; ++iy)
        oled.drawPixel(X+i, iy);
        else if (nexty<y) {
          for (uint8_t iy = nexty+1; iy<y; ++iy)
private:
    uint8_t waveform[MAXWAVE];
    uint8_t disp_wave[MAXWAVE];
    uint8_t wavep = 0;
} wave;
int  beatAvg;
int  SPO2, SPO2f;
int  voltage;
bool filter_for_graph = false;
bool draw_Red = false;
uint8_t pcflag =0;
uint8_t istate = 0;
uint8_t sleep_counter = 0;
void button(void){
    pcflag = 1;
void checkbutton(){
    if (pcflag && !digitalRead(BUTTON)) {
      istate = (istate +1) % 4;
      filter_for_graph = istate & 0x01;
      draw_Red = istate & 0x02;
      EEPROM.write(OPTIONS, filter_for_graph);
      EEPROM.write(OPTIONS+1, draw_Red);
    pcflag = 0;
void Display_5(){
   if(pcflag && !digitalRead(BUTTON)){
     draw_oled(5);
     delay(1100);
   pcflag = 0;
void go_sleep() {
    oled.fill(0);
    oled.off();
    delay(30);
    sensor.shutDown();
    delay(30);
    cbi(ADCSRA, ADEN);  // disable adc
    delay(30);
    pinMode(0,INPUT);
    pinMode(2,INPUT);
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);
    sleep_mode();  // sleep until button press
    // cause reset
    setup();
void draw_oled(int msg) {
    oled.firstPage();
    do{
    switch(msg){
        case 0:  oled.drawStr(10,0,F("Device error"),1);
        case 1:  oled.drawStr(0,0,F("PLACE YOUR"),2);
                 oled.drawStr(25,18,F("FINGER"),2);
        case 2:  print_digit(86,0,beatAvg);
                 oled.drawStr(0,3,F("PULSE RATE"),1);
                 oled.drawStr(11,17,F("OXYGEN"),1);
                 oled.drawStr(0,25,F("SATURATION"),1);
                 print_digit(73,16,SPO2f,' ',3,2);
                 oled.drawChar(116,16,'%',2);
        case 3:  oled.drawStr(33,0,F("Pulse"),2);
                 oled.drawStr(17,15,F("Oximeter"),2);
                 //oled.drawXBMP(6,8,16,16,heart_bits);
        case 4:  oled.drawStr(28,12,F("OFF IN"),1);
                 oled.drawChar(76,12,10-sleep_counter/10+'0');
                 oled.drawChar(82,12,'s');
        case 5:  oled.drawStr(0,0,F("Avg Pulse"),1);
                 print_digit(75,0,beatAvg);
                 oled.drawStr(0,15,F("AVG OXYGEN"),1);
                 oled.drawStr(0,22,F("saturation"),1);
                 print_digit(75,15,SPO2);
    } while (oled.nextPage());
void setup(void) {
  pinMode(LED, OUTPUT);
  pinMode(BUTTON, INPUT_PULLUP);
  pinMode(3, OUTPUT);
  filter_for_graph = EEPROM.read(OPTIONS);
  draw_Red = EEPROM.read(OPTIONS+1);
  oled.init();
  oled.fill(0x00);
  draw_oled(3);
  delay(3000);
  if (!sensor.begin())  {
    draw_oled(0);
    while (1);
  sensor.setup();
  attachInterrupt(digitalPinToInterrupt(BUTTON),button, CHANGE);
long lastBeat = 0;    //Time of the last beat
long displaytime = 0; //Time of the last display update
bool led_on = false;
void loop()  {
    sensor.check();
    long now = millis();   //start time of this cycle
    if (!sensor.available()) return;
    uint32_t irValue = sensor.getIR();
    uint32_t redValue = sensor.getRed();
    sensor.nextSample();
    if (irValue<5000) {
        voltage = getVCC();
        checkbutton();
        draw_oled(sleep_counter<=50 ? 1 : 4); // finger not down message
        //? : 是三元运算符,整个表达式根据条件返回不同的值,如果x>y为真则返回x,如果为假则返回y,之后=赋值给z。相当于:if(x>y)z=x;elsez=y
        delay(200);
        ++sleep_counter;
        if (sleep_counter>100) {
          go_sleep();
          sleep_counter = 0;
        sleep_counter = 0;
        // remove DC element移除直流元件
        int16_t IR_signal, Red_signal;
        bool beatRed, beatIR;
        if (!filter_for_graph) {//图形过滤器
           IR_signal =  pulseIR.dc_filter(irValue) ;
           Red_signal = pulseRed.dc_filter(redValue);
           beatRed = pulseRed.isBeat(pulseRed.ma_filter(Red_signal));
           beatIR =  pulseIR.isBeat(pulseIR.ma_filter(IR_signal));
           IR_signal =  pulseIR.ma_filter(pulseIR.dc_filter(irValue)) ;
           Red_signal = pulseRed.ma_filter(pulseRed.dc_filter(redValue));
           beatRed = pulseRed.isBeat(Red_signal);
           beatIR =  pulseIR.isBeat(IR_signal);
        // invert waveform to get classical BP waveshape
        wave.record(draw_Red ? -Red_signal : -IR_signal );
        // check IR or Red for heartbeat
        if (draw_Red ? beatRed : beatIR){
            long btpm = 60000/(now - lastBeat);
            if (btpm > 0 && btpm < 200) beatAvg = bpm.filter((int16_t)btpm);
            lastBeat = now;
            digitalWrite(LED, HIGH);
            led_on = true;
            // compute SpO2 ratio
            long numerator   = (pulseRed.avgAC() * pulseIR.avgDC())/256;
            long denominator = (pulseRed.avgDC() * pulseIR.avgAC())/256;
            int RX100 = (denominator>0) ? (numerator * 100)/denominator : 999;
            // using formula
            SPO2f = (10400 - RX100*17+50)/100;
            // from table
            if ((RX100>=0) && (RX100<184))
              SPO2 = pgm_read_byte_near(&spo2_table[RX100]);
        // update display every 50 ms if fingerdown
        if (now-displaytime>50) {
            displaytime = now;
            wave.scale();
            draw_oled(2);
        Display_5();
    // flash led for 25 ms
    if (led_on && (now - lastBeat)>25){
        digitalWrite(LED, LOW);
        led_on = false;
Welcome to the forum
Under what circumstances do you want the buzzer to sound and for how long ?
What will end the buzzer sounding ?
Is it an active buzzer that sounds when you apply a voltage to it or is it a passive buzzer that needs voltage pulses applied to it to make a sound ?
hi, sorry for the late reply! i want the buzzer to sound whenever the values change, or the sensor detects a heartbeat. it should also be continuous, if that’s possible, like an ecg monitor. i am using a passive buzzer module. thank you so much for the help!
Where in the sketch do you read the value(s) that you are monitoring, how much must they change before sounding the buzzer, how long should the buzzer sound ?
In general, to detect a change you would save the previously read value before reading a new one, perhaps each time through loop() or at a timed interval. Then you compare the previous value with the current value and if there has been a significant change, set a flag to indicate that the buzzer code should be run
hi, sorry, we figured it out with one slight problem: every time the buzzer beats, the screen turns off T.T
Please post your revised sketch
here it is, thank you so much!
#include "Pulse.h"
#include <EEPROM.h>
#ifndef cbi
#endif
#ifndef sbi
#endif
SSD1306 oled;
MAX30105 sensor;
Pulse pulseIR;
Pulse pulseRed;
MAFilter bpm;
#define BUTTON 3
#define OPTIONS 7
                                        0x00, 0x00 };
          3, 2, 1 } ;
int getVCC() {
  #if defined(_AVR_ATmega1284P_)
  #else
  #endif
  uint8_t low = ADCL;
  low = ADCL;
    uint8_t ff = field;
    do {
        val = val/10;
        --ff;
    } while (ff>0);
class Waveform {
  public:
      void scale() {
        uint8_t maxw = 0;
        uint8_t minw = 255;
    if (i<MAXWAVE-1) {
      if (nexty>y) {
        else if (nexty<y) {
private:
    uint8_t wavep = 0;
} wave;
int  beatAvg;
int  SPO2, SPO2f;
int  voltage;
uint8_t pcflag =0;
uint8_t istate = 0;
void button(void){
    pcflag = 1;
void checkbutton(){
    pcflag = 0;
void Display_5(){
     draw_oled(5);
     delay(1100);
   pcflag = 0;
void go_sleep() {
    oled.fill(0);
    oled.off();
    delay(30);
    sensor.shutDown();
    delay(30);
    delay(30);
    pinMode(0,INPUT);
    pinMode(2,INPUT);
    // cause reset
    setup();
    oled.firstPage();
    do{
    switch(msg){
        case 4:  oled.drawStr(0,0,F("Avg Pulse"),1);
void setup(void) {
  pinMode(3, OUTPUT);
  oled.init();
  oled.fill(0x00);
  draw_oled(3);
  delay(3000);
    draw_oled(0);
    while (1);
  sensor.setup();
void loop()  {
    sensor.check();
    if (irValue<5000) {
        voltage = getVCC();
        checkbutton();
        delay(200);
        ++sleep_counter;
          go_sleep();
          sleep_counter = 0;
        sleep_counter = 0;
            lastBeat = now;
            led_on = true;
            // using formula
            // from table
            tone(3,1000);                                        //And  tone the buzzer for a 100ms you can reduce it it will be better
            delay(100);
            noTone(3);
        if (now-displaytime>100) {
            displaytime = now;
            wave.scale();
            draw_oled(2);
        Display_5();
        led_on = false;
What happens if you use the duration parameter in teh tone() function instead of a delay() ?
hi! thank you so much for replying. i figured out the problem was that the code already stated something for digitalpin 3 and i was using the same pin for the buzzer. i simply changed the pin and it was solved.
