So, as a part of my project, I have to build an microfluidic droplet sorter, and this part I am making as of this writing on the form, I have two V114-5G-M5 Solenoid Valves, a breadboard and an Arduino Due. I wrote a code, but haven't tested it yet since I don't have some other parts.
I had an idea of using two diodes, resistors and transistors that correspond to two Solenoid Valves since only one Solenoid valve is using one of each component mentioned above.
Am I right in thinking that I could use two of each diode, resistor and transistors for this circuit? Or is there any other component that could be recommended?
EDIT: Instead of two transistors, can I use a IRLD110 MOSFET?
EDIT2: I was able to get the solenoid valves to work in the end.
The data sheet for that part is very hard to read. But it recommends control circuits, which you should study carefully.
What are the voltage/current/power specifications for the valve you ordered?
Note that breadboards are for temporary experiments with low power logic circuitry, and cannot tolerate the currents required by motors, servos and most solenoids.
For reliable functioning, solder your supporting circuitry on a permanent protoboard PCB, like this one.
