While loop does not function when volatile var is supposed to trigger it.
I am triggering an interrupt which works fine and immediately set the var to a value of 1 ( I have tried bool, uint8_t, and int) as types the same problem occurs. I intend to get rid of the interrupt in the future, but I know it works when the hall effect triggers it. I tried to use an if statement in the void loop() but that did not work so I put in the while (triggerState = 1); still no love. I have a lot of Serial.print lines I used for testing (sorry) If I trigger the hall effect with this code I get the Serial.print of the value of triggerState in the ISR
code follows:
Logic program to determine rotation direction and direction pointing
Rotation CW will be represented as value of 16 of the uint8_t
which will include the least significant bits 0-3 for values between
1 and 8 only. To indicate rotation direction if value is greater than
8 then CW else CCW. Values between 9 and 15 are invalid as is 0.
#include <VirtualWire.h>
//#include <SPI.h>
const uint8_t trigger = 2; // the number of the interrupt trigger pin
const uint8_t reed1 = 3; // Reed group pins 4-7 are BCD inputs
const uint8_t reed2 = 4; //
const uint8_t reed3 = 5; //
const uint8_t reed4 = 6; //
const uint8_t rotate = 11; // detects call to rotate antenna from base
const int ledPin = 13;
uint8_t value = 0;
uint8_t prev_value = 0; // Sets previous direction pointing to 0
uint8_t x = 0;
uint8_t triggered = 0;
uint8_t triggerState = 0;
uint8_t sum = 0; // calculated value of current plus previous values
uint8_t cw = 16; // sets CW indicator to false
uint8_t TX_buffer[1] = {0};
const uint8_t NUMBER = 4; // Array of inputs for BCD reading
uint8_t input_pin[NUMBER] = {3, 4, 5, 6};
uint8_t position[NUMBER] = {0};
bool runonce = false;
bool mot_ena = HIGH; // enables motor thru MOSFET
// variables will change:
//volatile uint8_t value = 0;
//volatile uint8_t triggerState = 0;
pinMode (trigger, INPUT);
pinMode (rotate, INPUT);
pinMode (trigger, INPUT); // Interrupt input from Hall effect
pinMode (ledPin, OUTPUT);
vw_set_tx_pin(12); // Transmit pin base data for direction and rotation
vw_setup(4000); // bps transmission speed of transmitter
TX_buffer[0] = 0;
attachInterrupt(digitalPinToInterrupt(trigger), conv, FALLING);
if ((sum == 15) || (sum == 9)) // determines if rotation went too far in either direction
digitalWrite (mot_ena, LOW);
delay (5000);
digitalWrite (mot_ena, HIGH);
Serial.print("triggerState0: "); // 0 printed at beginning of void
Serial.println(triggerState);
Serial.print("triggerState1: "); // 0 printed at beginning of while loop
TX_buffer[0] = value;
vw_send(TX_buffer, 1);
vw_wait_tx();
delay (2500);
x=x+1;
digitalWrite(ledPin, 1);
Serial.println("Triggered Value:");
Serial.print("\t");
Serial.println(value);
//triggerState = 0;
// ISR conv Converts inputs to integer reading reed switches 1,2,4,8. Triggered on hall effect input on interupt pin.
void conv()
// Current state should be equal to the 4 input BCD values.
triggerState = 1;
Serial.print("triggerState2: "); // Testing only (2 is only an indicator of
Serial.println(triggerState); // Testing only where it was printed from)
value = 0; //Resets value to zero, stops accumulation of value growing
position[1] = digitalRead(reed1);
value = value * 2 + position [1];
//digitalWrite (reed_1, position [1]);
position[2] = digitalRead(reed2);
value = value + position[2] * 2;
//digitalWrite (reed_2, position [2]);
position[3] = digitalRead(reed3);
value = value + position[3] * 4;
// digitalWrite (reed_3, position [4]);
position[4] = digitalRead(reed4);
value = value + position[4] * 8;
//digitalWrite (reed_4, position [8]);
if (value > prev_value)
cw = 16;
cw = 0;
value = value + cw;
cw = 16;
Serial.print ("previous Value: ");
Serial.println (prev_value);
Serial.print ("current value: ");
Serial.println("++++++++++++++++++");
sum = prev_value + value;
prev_value = value;
delay(25);
