While loop
I had a sketch working but changed the method to check on buttonpress. I now have the following algorithm that does nothing:
while (!Expose) {
      ReadButtons();}                                               // readbutton
      SwLEDs();
The function ReadButtons reads the buttons. In this case the button Expose that changes the vairable Expose from false to true when pressed. It should wait to start the function SwLEDs() until the button is pressed, but nada.
This is a common case where we need to see the whole sketch, because your issue hinges on how you modify the variable 'Expose' in the code that isn't shown.
Not to mensh that...
aarg:
... schematic, to see if the button is actually reliably switching anything.
jubukraa:
OP did mention that the previous sketch was working, so I doubt that this is necessary.
I bow to your post count. High post count always trumps low.
jubukraa:
I was simply pointing out a fact.
I had to narrow the sketch down a lot and came up with the following:
    boolean Sw[12];                     // array to hold the values read from buttons 0-9
    boolean &Expose     = Sw[0];        // use recognisable names for the different switches
    boolean &White      = Sw[1];
    boolean &Red        = Sw[2];
    boolean &Plus       = Sw[3];
    boolean &Minus      = Sw[4];
    boolean &Shift      = Sw[5];
    boolean &BurnProof  = Sw[6];
    boolean &Filter     = Sw[7];
    boolean &Paper      = Sw[8];
    boolean &Reset      = Sw[9];
    int Nr=5;
    boolean sw = false;                 // boolean to check if any switch is pressed (in that case sw=true, else false)
    int V1 = 300;                       // value 1 to check buttonpress: if analogread < V1 button 0 (or 3)
    int V2 = 750;                       // value 2 to check buttonpress: if V1 <= analogread < V2 button 1 (or 4); if analogread > V2, button 2 (or 5)
    int value;
    int PinBt[3] = {A0,A1,A2};
{   Serial.begin(9600);   }
{   while (!BurnProof) {
    SetNr();           }
    Serial.println (" Start again");
void SetNr(){
    ReadButtons;
    if (Plus  ) {Nr = Nr + 1 ;}
    if (Minus ) {Nr = Nr - 1 ;}
    Serial.println (Nr);
    return;
void ReadButtons()
{   for (int i=0; i<= 9; i++)
    {Sw[i] = false;}
    boolean sw = false;                                                // use sw to remember buttonstate and set to false (no button pressed)
      while (!sw)                                                      // keep reading until a button is pressed
      for (int j=0; j<= 1; j++)   {                                    // loop to read all inputs 2 times
      for (int i=0; i<= 2; i++) {                                      // loop to read the 3 inputs
      int value  = analogRead (PinBt[i]);                              // analogread input i
      if (value > 20) {
        sw = true;                                                     // only values > 20 are considered, in that case one of the buttons is pressed and sw is set to true
        int k = 3 * i ;                                                // calculate which button is pressed:
        if (sw && value < V1) {Sw[k] = true;}               // Serial.println(k);}                          // if value greater than 50 and less than V1 it was switch k that was pressed
        if (value >= V1 && value <= V2) {Sw[k+1] = true;}   //Serial.println(k+1);}                         // if value greater than V1 and smaller than V2 it was switch k+1 that was pressed
        if (value >= V2) {Sw[k+2] = true;}                  //Serial.println(k+2);}                         // if value greater than V2 it was switch k+2 that was pressed
      delay (200);              } } }                                   // delay to debounce
      for (int i=0; i<=8; i++)    {
      if (Sw[i])
      {Serial.print ("Sw "); Serial.println (i);   }}
      Serial.println ("sw0, sw 1, sw2, sw3, sw4, sw5, sw6, sw7, sw8");
      Serial.print (Expose);Serial.print(White); Serial.print(Red); Serial.print(Plus);
      Serial.print( Minus); Serial.print(Shift); Serial.print(BurnProof); Serial.print(Filter); Serial.println(Paper);
    return;
ReadButtons is never called - you missed out the trailing brackets that would make it a function call.
OK, think them there. This is not the sketch in question but a sketsch to demonstrate the workings:
The ReadButtons() functions works, it sets the viariable " Sw* " (the text doesnt show square bracket i square bracket) to true when button i is pressed. otherwise all Sw are false. No problem there,*
The function SetNr() is not an actual function but one for testing.
I would expect the loop to change Nr when the Sw[3] or Sw[4] button is pressed (Sw[6] will be false) and to print "Start again" when the button Sw[6] is pressed. This should change the value of Sw[6] to true, thus falsifying the while statement and exiting to the print of "Start again".
While (!x) ... means: as long as x = false do ..., doesn't it?
} } } Don't you just hate it when that happens?
TheMemberFormerlyKnownAsAWOL:
Yep.
The OP has the most unique, not to mention confusing and unreadable, indentation and brace style that I think I’ve ever seen. And I’ve seen a few in my time....
swdick:
A demonstration sketch should still compile and run. It eliminates guesswork.
Thanks, guys.
Now as for my question?
Let's start with a more conventionally formatted version courtesy of Auto format in the IDE
int Nr = 5;
int value;
int PinBt[3] = {A0, A1, A2};
  while (!BurnProof)
    SetNr();
void SetNr()
  ReadButtons;
  if (Plus  )
    Nr = Nr + 1 ;
  if (Minus )
    Nr = Nr - 1 ;
  return;
void ReadButtons()
  for (int i = 0; i <= 9; i++)
    Sw[i] = false;
    for (int j = 0; j <= 1; j++)                                     // loop to read all inputs 2 times
      for (int i = 0; i <= 2; i++)                                     // loop to read the 3 inputs
        if (value > 20)
            Sw[k] = true; // if value greater than 50 and less than V1 it was switch k that was pressed
            Sw[k + 1] = true; // if value greater than V1 and smaller than V2 it was switch k+1 that was pressed
          if (value >= V2)
            Sw[k + 2] = true; // if value greater than V2 it was switch k+2 that was pressed
          delay (200);
    for (int i = 0; i <= 8; i++)
      if (Sw[i])
        Serial.println (i);
    Serial.print(Red);
    Serial.print(Plus);
  return;
Thanks. I simplified the sketch to get it more to the point. Now it seems to work.
It prints something while it is in the while loop and something else when I press 0.
I learned how to use the while statement and how to use a referenced variable. Thanks a lot.
boolean Sw[1];                          // array to hold the values read from buttons 0-9
boolean &Expose = Sw[0] = false;        // use recognisable names for the different switches
char rx_byte = 0;
  while (!Expose)
    ReadButtons();
    delay (1000);
    Serial.println ("While condition fullfilled");
  Serial.println ("While condition no longer fullfilled");
  Expose = false;
void ReadButtons()
  rx_byte = 0;
  Sw[0] = false;
  if (Serial.available() > 0)
    rx_byte = Serial.read();
    Serial.print("Number received: "); Serial.println(rx_byte);
    if ((rx_byte == '0') )
      Sw[0] = true;
