Hi, I have a problem when I run my stepper motor 17HS4001 12v,1.7A by DRV8825 ( vref = 0.85v), everything is fine when he turns but after stopping I hear a whistle from the motor, I don't know why, and if there is any method to reduce it
Note: When I reduce vref to 0.5v the whistle disappear, but this is not a good method because the necessary current is 1.7A so vref = 0.85v
/* stepper motor control code for DRV8825
// define pin used
const int stepPin = 8;
const int dirPin = 9;
// set the two pins as outputs
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
digitalWrite(dirPin,HIGH); //Enables the motor to move in a perticular direction
// for one full rotation required 200 pulses
for(int x = 0; x < 900; x++){
digitalWrite(stepPin,HIGH);
delayMicroseconds(500);
digitalWrite(stepPin,LOW);
delay(2000); // delay for one second
Different stepper drivers will have different chopping frequencies and different degrees of audible whining,
but they all have it at some level. Different motors will have different mechanical resonances too.
