White screen problem in tft lcd display
Similar to others in the previous conversations in this forum, i am also facing the same problem. no matter what i try the screen just remains white. Yesterday when dumped a code of adafruit_TFTLCD, I was able to see something on the screen (not very clearly). Today i couldn't see anything. On reading the previous forums, I tried mcufriend_kbv --> LCD_ID readreg and these are it's serial monitor output :point_down:
controllers either read as single 16-bit
e.g. the ID is at readReg(0)
or as a sequence of 8-bit values
in special locations (first is dummy)
reg(0x0000) 00 00 ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 00 00 00 00 Manufacturer ID
reg(0x0009) 00 00 41 00 00 Status Register
reg(0x000A) 00 08 Get Power Mode
reg(0x000C) 00 06 Get Pixel Format
reg(0x0061) 20 20 RDID1 HX8347-G
reg(0x0062) 20 20 RDID2 HX8347-G
reg(0x0063) 20 20 RDID3 HX8347-G
reg(0x0064) 20 20 RDID1 HX8347-A
reg(0x0065) 20 20 RDID2 HX8347-A
reg(0x0066) 20 20 RDID3 HX8347-A
reg(0x0067) 20 20 RDID Himax HX8347-A
reg(0x0070) 20 20 Panel Himax HX8347-A
reg(0x00A1) 20 20 20 20 20 RD_DDB SSD1963
reg(0x00B0) 20 20 RGB Interface Signal Control
reg(0x00B4) 20 22 Inversion Control
reg(0x00B6) 20 2A A2 27 24 Display Control
reg(0x00B7) 20 26 Entry Mode Set
reg(0x00BF) 20 20 20 20 20 20 ILI9481, HX8357-B
reg(0x00C0) 00 01 00 00 00 00 00 00 00 Panel Control
reg(0x00C8) 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA
reg(0x00CC) 00 51 Panel Control
reg(0x00D0) 00 00 00 Power Control
reg(0x00D2) 00 00 00 03 03 NVM Read
reg(0x00D3) 00 00 93 41 ILI9341, ILI9488
reg(0x00D4) 00 00 00 00 Novatek ID
reg(0x00DA) 00 00 RDID1
reg(0x00DB) 00 00 RDID2
reg(0x00DC) 00 00 RDID3
reg(0x00E0) 20 2F 36 34 2A 2D 26 63 75 33 26 2E 20 2C 29 28 GAMMA-P
reg(0x00E1) 20 28 2B 2D 24 30 24 3E 24 6E 24 2F 2E 35 38 2F GAMMA-N
reg(0x00EF) 20 23 A0 22 22 22 ILI9327
reg(0x00F2) 20 22 22 22 22 22 22 22 22 22 22 22 Adjust Control 2
reg(0x00F6) 20 21 20 20 Interface Control
I'm really in need of the solution, thanks
Show the sketch and the link to the library in use.
Also, show a picture of the numbers on the ICs of the TFT.
// All the mcufriend.com UNO shields have the same pinout.
// i.e. control pins A0-A4.  Data D2-D9.  microSD D10-D13.
// Touchscreens are normally A1, A2, D7, D6 but the order varies
// This demo should work with most Adafruit TFT libraries
// If you are not using a shield,  use a full Adafruit constructor()
// e.g. Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
#include <SPI.h>          // f.k. for Arduino-1.5.2
#include "Adafruit_GFX.h"// Hardware-specific library
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
//#include <Adafruit_TFTLCD.h>
//Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// Assign human-readable names to some common 16-bit color values:
#define	BLACK   0x0000
#define	BLUE    0x001F
#define	RED     0xF800
#define	GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#ifndef min
#define min(a, b) (((a) < (b)) ? (a) : (b))
#endif
void setup(void);
void loop(void);
unsigned long testFillScreen();
unsigned long testText();
unsigned long testLines(uint16_t color);
unsigned long testFastLines(uint16_t color1, uint16_t color2);
unsigned long testRects(uint16_t color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2);
unsigned long testFilledCircles(uint8_t radius, uint16_t color);
unsigned long testCircles(uint8_t radius, uint16_t color);
unsigned long testTriangles();
unsigned long testFilledTriangles();
unsigned long testRoundRects();
unsigned long testFilledRoundRects();
void progmemPrint(const char *str);
void progmemPrintln(const char *str);
void runtests(void);
uint16_t g_identifier;
extern const uint8_t hanzi[];
void showhanzi(unsigned int x, unsigned int y, unsigned char index)
    uint8_t i, j, c, first = 1;
    uint8_t *temp = (uint8_t*)hanzi;
    uint16_t color;
    tft.setAddrWindow(x, y, x + 31, y + 31); //设置区域
    temp += index * 128;
    for (j = 0; j < 128; j++)
        c = pgm_read_byte(temp);
        for (i = 0; i < 8; i++)
            if ((c & (1 << i)) != 0)
                color = RED;
                color = BLACK;
            tft.pushColors(&color, 1, first);
            first = 0;
        temp++;
void setup(void) {
    uint32_t when = millis();
    //    while (!Serial) ;   //hangs a Leonardo until you connect a Serial
    if (!Serial) delay(5000);           //allow some time for Leonardo
    Serial.println("Serial took " + String((millis() - when)) + "ms to start");
    //    tft.reset();                 //hardware reset
    uint16_t ID = tft.readID(); //
    Serial.print("ID = 0x");
    Serial.println(ID, HEX);
    if (ID == 0xD3D3) ID = 0x9481; // write-only shield
//    ID = 0x9329;                             // force ID
    tft.begin(ID);
#if defined(MCUFRIEND_KBV_H_)
uint16_t scrollbuf[320];    // my biggest screen is 320x480
#define READGRAM(x, y, buf, w, h)  tft.readGRAM(x, y, buf, w, h)
#else
uint16_t scrollbuf[320];    // Adafruit only does 240x320
// Adafruit can read a block by one pixel at a time
int16_t  READGRAM(int16_t x, int16_t y, uint16_t *block, int16_t w, int16_t h)
    uint16_t *p;
    for (int row = 0; row < h; row++) {
        p = block + row * w;
        for (int col = 0; col < w; col++) {
            *p++ = tft.readPixel(x + col, y + row);
#endif
void windowScroll(int16_t x, int16_t y, int16_t wid, int16_t ht, int16_t dx, int16_t dy, uint16_t *buf)
    if (dx) for (int16_t row = 0; row < ht; row++) {
            READGRAM(x, y + row, buf, wid, 1);
            tft.setAddrWindow(x, y + row, x + wid - 1, y + row);
            tft.pushColors(buf + dx, wid - dx, 1);
            tft.pushColors(buf + 0, dx, 0);
    if (dy) for (int16_t col = 0; col < wid; col++) {
            READGRAM(x + col, y, buf, 1, ht);
            tft.setAddrWindow(x + col, y, x + col, y + ht - 1);
            tft.pushColors(buf + dy, ht - dy, 1);
            tft.pushColors(buf + 0, dy, 0);
void printmsg(int row, const char *msg)
    tft.setTextColor(YELLOW, BLACK);
    tft.setCursor(0, row);
    tft.println(msg);
void loop(void) {
    uint8_t aspect;
    uint16_t pixel;
    const char *aspectname[] = {
        "PORTRAIT", "LANDSCAPE", "PORTRAIT_REV", "LANDSCAPE_REV"
    const char *colorname[] = { "BLUE", "GREEN", "RED", "GRAY" };
    uint16_t colormask[] = { 0x001F, 0x07E0, 0xF800, 0xFFFF };
    uint16_t dx, rgb, n, wid, ht, msglin;
    tft.setRotation(0);
    runtests();
    delay(2000);
    if (tft.height() > 64) {
        for (uint8_t cnt = 0; cnt < 4; cnt++) {
            aspect = (cnt + 0) & 3;
            tft.setRotation(aspect);
            wid = tft.width();
            ht = tft.height();
            msglin = (ht > 160) ? 200 : 112;
            testText();
            dx = wid / 32;
            for (n = 0; n < 32; n++) {
                rgb = n * 8;
                rgb = tft.color565(rgb, rgb, rgb);
                tft.fillRect(n * dx, 48, dx, 63, rgb & colormask[aspect]);
            tft.drawRect(0, 48 + 63, wid, 1, WHITE);
            tft.setTextSize(2);
            tft.setTextColor(colormask[aspect], BLACK);
            tft.setCursor(0, 72);
            tft.print(colorname[aspect]);
            tft.setTextColor(WHITE);
            tft.println(" COLOR GRADES");
            tft.setTextColor(WHITE, BLACK);
            printmsg(184, aspectname[aspect]);
            tft.drawPixel(0, 0, YELLOW);
            pixel = tft.readPixel(0, 0);
            tft.setTextSize((ht > 160) ? 2 : 1); //for messages
#if 1
            extern const uint8_t penguin[];
            tft.setAddrWindow(wid - 40 - 40, 20 + 0, wid - 1 - 40, 20 + 39);
            tft.pushColors(penguin, 1600, 1);
#elif 1
            extern const uint8_t wifi_full[];
            tft.setAddrWindow(wid - 40 - 40, 20 + 0, wid - 40 - 40 + 31, 20 + 31);
            tft.pushColors(wifi_full, 1024, 1, true);
#elif 1
            extern const uint8_t icon_40x40[];
            tft.pushColors(icon_40x40, 1600, 1);
#endif
            tft.setAddrWindow(0, 0, wid - 1, ht - 1);
            if (aspect & 1) tft.drawRect(wid - 1, 0, 1, ht, WHITE);
            else tft.drawRect(0, ht - 1, wid, 1, WHITE);
            printmsg(msglin, "VERTICAL SCROLL UP");
            uint16_t maxscroll;
            if (tft.getRotation() & 1) maxscroll = wid;
            else maxscroll = ht;
            for (uint16_t i = 1; i <= maxscroll; i++) {
                tft.vertScroll(0, maxscroll, i);
                delay(10);
			printmsg(msglin, "VERTICAL SCROLL DN");
                tft.vertScroll(0, maxscroll, 0 - (int16_t)i);
                delay(10);
			tft.vertScroll(0, maxscroll, 0);
            printmsg(msglin, "SCROLL DISABLED   ");
            if ((aspect & 1) == 0) { //Portrait
                tft.setTextColor(BLUE, BLACK);
                printmsg(msglin, "ONLY THE COLOR BAND");
                for (uint16_t i = 1; i <= 64; i++) {
                    tft.vertScroll(48, 64, i);
                    delay(20);
#endif
            if (pixel == YELLOW) {
                printmsg(msglin, "SOFTWARE SCROLL    ");
#if 0
                // diagonal scroll of block
                for (int16_t i = 45, dx = 2, dy = 1; i > 0; i -= dx) {
                    windowScroll(24, 8, 90, 40, dx, dy, scrollbuf);
#else
                // plain horizontal scroll of block
                n = (wid > 320) ? 320 : wid;
                for (int16_t i = n, dx = 4, dy = 0; i > 0; i -= dx) {
                    windowScroll(0, 200, n, 16, dx, dy, scrollbuf);
#endif
            else if (pixel == CYAN)
                tft.println("readPixel() reads as BGR");
            else if ((pixel & 0xF8F8) == 0xF8F8)
                tft.println("readPixel() should be 24-bit");
            else {
                tft.print("readPixel() reads 0x");
                tft.println(pixel, HEX);
            delay(5000);
    printmsg(msglin, "INVERT DISPLAY ");
    tft.invertDisplay(true);
    delay(2000);
    tft.invertDisplay(false);
typedef struct {
    PGM_P msg;
    uint32_t ms;
} TEST;
TEST result[12];
#define RUNTEST(n, str, test) { result[n].msg = PSTR(str); result[n].ms = test; delay(500); }
void runtests(void)
    uint8_t i, len = 24, cnt;
    uint32_t total;
    RUNTEST(0, "FillScreen               ", testFillScreen());
    RUNTEST(1, "Text                     ", testText());
    RUNTEST(2, "Lines                    ", testLines(CYAN));
    RUNTEST(3, "Horiz/Vert Lines         ", testFastLines(RED, BLUE));
    RUNTEST(4, "Rectangles (outline)     ", testRects(GREEN));
    RUNTEST(5, "Rectangles (filled)      ", testFilledRects(YELLOW, MAGENTA));
    RUNTEST(6, "Circles (filled)         ", testFilledCircles(10, MAGENTA));
    RUNTEST(7, "Circles (outline)        ", testCircles(10, WHITE));
    RUNTEST(8, "Triangles (outline)      ", testTriangles());
    RUNTEST(9, "Triangles (filled)       ", testFilledTriangles());
    RUNTEST(10, "Rounded rects (outline)  ", testRoundRects());
    RUNTEST(11, "Rounded rects (filled)   ", testFilledRoundRects());
    tft.fillScreen(BLACK);
    tft.setTextColor(GREEN);
    tft.setCursor(0, 0);
    uint16_t wid = tft.width();
    if (wid > 176) {
        tft.setTextSize(2);
        tft.print("MCUFRIEND ");
#if MCUFRIEND_KBV_H_ != 0
        tft.print(0.01 * MCUFRIEND_KBV_H_, 2);
#else
        tft.print("for");
#endif
        tft.println(" UNO");
#else
        tft.println("Adafruit-Style Tests");
#endif
    } else len = wid / 6 - 8;
    tft.setTextSize(1);
    total = 0;
    for (i = 0; i < 12; i++) {
        PGM_P str = result[i].msg;
        char c;
        if (len > 24) {
            if (i < 10) tft.print(" ");
            tft.print(i);
            tft.print(": ");
        uint8_t cnt = len;
        while ((c = pgm_read_byte(str++)) && cnt--) tft.print(c);
        tft.print(" ");
        tft.println(result[i].ms);
        total += result[i].ms;
    tft.setTextSize(2);
    tft.print("Total:");
    tft.print(0.000001 * total);
    tft.println("sec");
    g_identifier = tft.readID();
    tft.print("ID: 0x");
    tft.println(tft.readID(), HEX);
//    tft.print("Reg(00):0x");
//    tft.println(tft.readReg(0x00), HEX);
    tft.print("F_CPU:");
    tft.print(0.000001 * F_CPU);
#if defined(__OPTIMIZE_SIZE__)
    tft.println("MHz -Os");
#else
    tft.println("MHz");
#endif
    delay(10000);
// Standard Adafruit tests.  will adjust to screen size
unsigned long testFillScreen() {
    unsigned long start = micros();
    tft.fillScreen(RED);
    tft.fillScreen(GREEN);
    tft.fillScreen(BLUE);
    return micros() - start;
unsigned long testText() {
    unsigned long start;
    start = micros();
    tft.setTextColor(WHITE);  tft.setTextSize(1);
    tft.println("Hello World!");
    tft.setTextColor(YELLOW); tft.setTextSize(2);
    tft.println(123.45);
    tft.setTextColor(RED);    tft.setTextSize(3);
    tft.println(0xDEADBEEF, HEX);
    tft.println();
    tft.setTextSize(5);
    tft.println("Groop");
    tft.setTextSize(2);
    tft.println("I implore thee,");
    tft.setTextSize(1);
    tft.println("my foonting turlingdromes.");
    tft.println("And hooptiously drangle me");
    tft.println("with crinkly bindlewurdles,");
    tft.println("Or I will rend thee");
    tft.println("in the gobberwarts");
    tft.println("with my blurglecruncheon,");
    tft.println("see if I don't!");
unsigned long testLines(uint16_t color) {
    unsigned long start, t;
    int           x1, y1, x2, y2,
                  w = tft.width(),
                  h = tft.height();
    x1 = y1 = 0;
    y2    = h - 1;
    start = micros();
    for (x2 = 0; x2 < w; x2 += 6) tft.drawLine(x1, y1, x2, y2, color);
    x2    = w - 1;
    for (y2 = 0; y2 < h; y2 += 6) tft.drawLine(x1, y1, x2, y2, color);
    t     = micros() - start; // fillScreen doesn't count against timing
    x1    = w - 1;
    y1    = 0;
    y2    = h - 1;
    start = micros();
    x2    = 0;
    t    += micros() - start;
    x1    = 0;
    y1    = h - 1;
    y2    = 0;
    start = micros();
    x2    = w - 1;
    x1    = w - 1;
    y1    = h - 1;
    y2    = 0;
    start = micros();
    x2    = 0;
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
    int           x, y, w = tft.width(), h = tft.height();
    start = micros();
    for (y = 0; y < h; y += 5) tft.drawFastHLine(0, y, w, color1);
    for (x = 0; x < w; x += 5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
    int           n, i, i2,
                  cx = tft.width()  / 2,
                  cy = tft.height() / 2;
    n     = min(tft.width(), tft.height());
    start = micros();
    for (i = 2; i < n; i += 6) {
        i2 = i / 2;
        tft.drawRect(cx - i2, cy - i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
    unsigned long start, t = 0;
    int           n, i, i2,
                  cx = tft.width()  / 2 - 1,
                  cy = tft.height() / 2 - 1;
    for (i = n; i > 0; i -= 6) {
        i2    = i / 2;
        start = micros();
        tft.fillRect(cx - i2, cy - i2, i, i, color1);
        // Outlines are not included in timing results
        tft.drawRect(cx - i2, cy - i2, i, i, color2);
    return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
    int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
    start = micros();
    for (x = radius; x < w; x += r2) {
        for (y = radius; y < h; y += r2) {
            tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
    int           x, y, r2 = radius * 2,
                        w = tft.width()  + radius,
                        h = tft.height() + radius;
    // Screen is not cleared for this one -- this is
    // intentional and does not affect the reported time.
    start = micros();
    for (x = 0; x < w; x += r2) {
        for (y = 0; y < h; y += r2) {
            tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
    int           n, i, cx = tft.width()  / 2 - 1,
    n     = min(cx, cy);
    start = micros();
    for (i = 0; i < n; i += 5) {
        tft.drawTriangle(
            cx    , cy - i, // peak
            cx - i, cy + i, // bottom left
            cx + i, cy + i, // bottom right
            tft.color565(0, 0, i));
unsigned long testFilledTriangles() {
    int           i, cx = tft.width()  / 2 - 1,
    start = micros();
    for (i = min(cx, cy); i > 10; i -= 5) {
        start = micros();
        tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
                         tft.color565(0, i, i));
        tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
                         tft.color565(i, i, 0));
    return t;
unsigned long testRoundRects() {
    int           w, i, i2, red, step,
    w     = min(tft.width(), tft.height());
    start = micros();
    red = 0;
    step = (256 * 6) / w;
    for (i = 0; i < w; i += 6) {
        i2 = i / 2;
        red += step;
        tft.drawRoundRect(cx - i2, cy - i2, i, i, i / 8, tft.color565(red, 0, 0));
unsigned long testFilledRoundRects() {
    int           i, i2, green, step,
    start = micros();
    green = 256;
    step = (256 * 6) / min(tft.width(), tft.height());
    for (i = min(tft.width(), tft.height()); i > 20; i -= 6) {
        i2 = i / 2;
        green -= step;
        tft.fillRoundRect(cx - i2, cy - i2, i, i, i / 8, tft.color565(0, green, 0));
and
// adapted from LCD_ID_Reader from http://misc.ws/lcd_information
// controllers either read as 16-bit or as a sequence of 8-bit values
//-- Arduino UNO or Mega 2560 Plugged as shield
#define LCD_RST A4
#define LCD_CS A3
#define LCD_RS A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_D0 8
#define LCD_D1 9
#define LCD_D2 2
#define LCD_D3 3
#define LCD_D4 4
#define LCD_D5 5
#define LCD_D6 6
#define LCD_D7 7
    while (!Serial) ;
    Serial.println("Read Registers on MCUFRIEND UNO shield");
    Serial.println("controllers either read as single 16-bit");
    Serial.println("e.g. the ID is at readReg(0)");
    Serial.println("or as a sequence of 8-bit values");
    Serial.println("in special locations (first is dummy)");
    Serial.println("");
    lcdInit();
    lcdReset();      //ensures that controller is in default state
//    for (uint16_t i = 0; i < 256; i++) readReg(i, 7, "f.k");
    readReg(0x00, 2, "ID: ILI9320, ILI9325, ILI9335, ...");
    readReg(0x04, 4, "Manufacturer ID");
    readReg(0x09, 5, "Status Register");
    readReg(0x0A, 2, "Get Power Mode");
    readReg(0x0C, 2, "Get Pixel Format");
    readReg(0x61, 2, "RDID1 HX8347-G");
    readReg(0x62, 2, "RDID2 HX8347-G");
    readReg(0x63, 2, "RDID3 HX8347-G");
    readReg(0x64, 2, "RDID1 HX8347-A");
    readReg(0x65, 2, "RDID2 HX8347-A");
    readReg(0x66, 2, "RDID3 HX8347-A");
    readReg(0x67, 2, "RDID Himax HX8347-A");
    readReg(0x70, 2, "Panel Himax HX8347-A");
    readReg(0xA1, 5, "RD_DDB SSD1963");
    readReg(0xB0, 2, "RGB Interface Signal Control");
    readReg(0xB4, 2, "Inversion Control");
    readReg(0xB6, 5, "Display Control");
    readReg(0xB7, 2, "Entry Mode Set");
    readReg(0xBF, 6, "ILI9481, HX8357-B");
    readReg(0xC0, 9, "Panel Control");
    readReg(0xC8, 13, "GAMMA");
    readReg(0xCC, 2, "Panel Control");
    readReg(0xD0, 3, "Power Control");
    readReg(0xD2, 5, "NVM Read");
    readReg(0xD3, 4, "ILI9341, ILI9488");
    readReg(0xD4, 4, "Novatek ID");
    readReg(0xDA, 2, "RDID1");
    readReg(0xDB, 2, "RDID2");
    readReg(0xDC, 2, "RDID3");
    readReg(0xE0, 16, "GAMMA-P");
    readReg(0xE1, 16, "GAMMA-N");
    readReg(0xEF, 6, "ILI9327");
    readReg(0xF2, 12, "Adjust Control 2");
    readReg(0xF6, 4, "Interface Control");
void printhex(uint8_t val)
    if (val < 0x10) Serial.print("0");
    Serial.print(val, HEX);
void readReg(uint16_t reg, uint8_t n, const char *msg)
    uint8_t val8;
    lcdReset();
    lcdSetWriteDir();
    lcdWriteCommand(0xB0);     //Command Access Protect
    lcdWriteData(0x00);        //looks wrong
    lcdWriteCommand(0xF6);
    lcdWriteData(0x01);
    lcdWriteData(0x01);
    lcdWriteData(0x03);
    lcdWriteCommand(reg);
    Serial.print("reg(0x");
    printhex(reg >> 8);
    printhex(reg);
    Serial.print(")");
    lcdSetReadDir();
    while (n--) {
        val8 = lcdReadData8();
        Serial.print(" ");
        printhex(val8);
    lcdSetWriteDir();
    Serial.print("\t");
    Serial.println(msg);
void lcdInit()
    pinMode(LCD_CS, OUTPUT);
    digitalWrite(LCD_CS, HIGH);
    pinMode(LCD_RS, OUTPUT);
    digitalWrite(LCD_RS, HIGH);
    pinMode(LCD_WR, OUTPUT);
    digitalWrite(LCD_WR, HIGH);
    pinMode(LCD_RD, OUTPUT);
    digitalWrite(LCD_RD, HIGH);
    pinMode(LCD_RST, OUTPUT);
    digitalWrite(LCD_RST, HIGH);
void lcdReset()
    digitalWrite(LCD_RST, LOW);
    delay(2);
    delay(10);             //allow controller to re-start
void lcdWrite8(uint16_t data)
    digitalWrite(LCD_D0, data & 1);
    digitalWrite(LCD_D1, (data & 2) >> 1);
    digitalWrite(LCD_D2, (data & 4) >> 2);
    digitalWrite(LCD_D3, (data & 8) >> 3);
    digitalWrite(LCD_D4, (data & 16) >> 4);
    digitalWrite(LCD_D5, (data & 32) >> 5);
    digitalWrite(LCD_D6, (data & 64) >> 6);
    digitalWrite(LCD_D7, (data & 128) >> 7);
uint16_t lcdRead8()
    uint16_t result = digitalRead(LCD_D7);
    result <<= 1;
    result |= digitalRead(LCD_D6);
    result <<= 1;
    result |= digitalRead(LCD_D5);
    result <<= 1;
    result |= digitalRead(LCD_D4);
    result <<= 1;
    result |= digitalRead(LCD_D3);
    result <<= 1;
    result |= digitalRead(LCD_D2);
    result <<= 1;
    result |= digitalRead(LCD_D1);
    result <<= 1;
    result |= digitalRead(LCD_D0);
    return result;
void lcdSetWriteDir()
    pinMode(LCD_D0, OUTPUT);
    pinMode(LCD_D1, OUTPUT);
    pinMode(LCD_D2, OUTPUT);
    pinMode(LCD_D3, OUTPUT);
    pinMode(LCD_D4, OUTPUT);
    pinMode(LCD_D5, OUTPUT);
    pinMode(LCD_D6, OUTPUT);
    pinMode(LCD_D7, OUTPUT);
void lcdSetReadDir()
    pinMode(LCD_D0, INPUT);
    pinMode(LCD_D1, INPUT);
    pinMode(LCD_D2, INPUT);
    pinMode(LCD_D3, INPUT);
    pinMode(LCD_D4, INPUT);
    pinMode(LCD_D5, INPUT);
    pinMode(LCD_D6, INPUT);
    pinMode(LCD_D7, INPUT);
void lcdWriteData(uint16_t data)
    lcdSetWriteDir();
    digitalWrite(LCD_CS, LOW);
    lcdWrite8(data >> 8);
    digitalWrite(LCD_WR, LOW);
    delayMicroseconds(10);
    lcdWrite8(data);
void lcdWriteCommand(uint16_t command)
    lcdSetWriteDir();
    digitalWrite(LCD_RS, LOW);
    lcdWrite8(command >> 8);
    lcdWrite8(command);
uint8_t lcdReadData8()
    uint8_t result;
    lcdSetReadDir();
    digitalWrite(LCD_RD, LOW);
    result = lcdRead8();
    return result;
uint16_t lcdReadData16()
    uint16_t result;
    result = lcdReadData8() << 8;
    result |= lcdReadData8();
    return result;
void lcdWriteRegister(uint16_t addr, uint16_t data)
    lcdWriteCommand(addr);
    lcdWriteData(data);
are the codes i tried to run
and i was expecting the tests to happen like i saw in few videos but my screen just remained white (but i could see the brightness level being adjusted during execution of the both codes)
and about my wirings... no wirings i just mounted the tft display on the arduino uno board
i have tried using libraries such as
i mentioned earlier was able to see something, for that i used the following code (however even this code is not working now)
// IMPORTANT: Adafruit_TFTLCD LIBRARY MUST BE SPECIFICALLY
// CONFIGURED FOR EITHER THE TFT SHIELD OR THE BREAKOUT BOARD.
// SEE RELEVANT COMMENTS IN Adafruit_TFTLCD.h FOR SETUP.
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD:
// For the Arduino Uno, Duemilanove, Diecimila, etc.:
//   D0 connects to digital pin 8  (Notice these are
//   D1 connects to digital pin 9   NOT in order!)
//   D2 connects to digital pin 2
//   D3 connects to digital pin 3
//   D4 connects to digital pin 4
//   D5 connects to digital pin 5
//   D6 connects to digital pin 6
//   D7 connects to digital pin 7
// For the Arduino Mega, use digital pins 22 through 29
// (on the 2-row header at the end of the board).
#define	BLUE    0x001F
#define	RED     0xF800
#define CYAN    0x07FF
// If using the shield, all control and data lines are fixed, and
// a simpler declaration can optionally be used:
// Adafruit_TFTLCD tft;
void setup(void) {
  Serial.println(F("TFT LCD test"));
#ifdef USE_ADAFRUIT_SHIELD_PINOUT
  Serial.println(F("Using Adafruit 2.8\" TFT Arduino Shield Pinout"));
#else
  Serial.println(F("Using Adafruit 2.8\" TFT Breakout Board Pinout"));
#endif
  Serial.print("TFT size is "); Serial.print(tft.width()); Serial.print("x"); Serial.println(tft.height());
  tft.reset();
  uint16_t identifier = tft.readID();
  if(identifier == 0x9325) {
    Serial.println(F("Found ILI9325 LCD driver"));
  } else if(identifier == 0x9328) {
    Serial.println(F("Found ILI9328 LCD driver"));
  } else if(identifier == 0x7575) {
    Serial.println(F("Found HX8347G LCD driver"));
  } else if(identifier == 0x9341) {
    Serial.println(F("Found ILI9341 LCD driver"));
  } else if(identifier == 0x8357) {
    Serial.println(F("Found HX8357D LCD driver"));
    Serial.print(F("Unknown LCD driver chip: "));
    Serial.println(identifier, HEX);
    Serial.println(F("If using the Adafruit 2.8\" TFT Arduino shield, the line:"));
    Serial.println(F("  #define USE_ADAFRUIT_SHIELD_PINOUT"));
    Serial.println(F("should appear in the library header (Adafruit_TFT.h)."));
    Serial.println(F("If using the breakout board, it should NOT be #defined!"));
    Serial.println(F("Also if using the breakout, double-check that all wiring"));
    Serial.println(F("matches the tutorial."));
    return;
  tft.begin(identifier);
  Serial.println(F("Benchmark                Time (microseconds)"));
  Serial.print(F("Screen fill              "));
  Serial.println(testFillScreen());
  Serial.print(F("Text                     "));
  Serial.println(testText());
  delay(3000);
  Serial.print(F("Lines                    "));
  Serial.println(testLines(CYAN));
  Serial.print(F("Horiz/Vert Lines         "));
  Serial.println(testFastLines(RED, BLUE));
  Serial.print(F("Rectangles (outline)     "));
  Serial.println(testRects(GREEN));
  Serial.print(F("Rectangles (filled)      "));
  Serial.println(testFilledRects(YELLOW, MAGENTA));
  Serial.print(F("Circles (filled)         "));
  Serial.println(testFilledCircles(10, MAGENTA));
  Serial.print(F("Circles (outline)        "));
  Serial.println(testCircles(10, WHITE));
  Serial.print(F("Triangles (outline)      "));
  Serial.println(testTriangles());
  Serial.print(F("Triangles (filled)       "));
  Serial.println(testFilledTriangles());
  Serial.print(F("Rounded rects (outline)  "));
  Serial.println(testRoundRects());
  Serial.print(F("Rounded rects (filled)   "));
  Serial.println(testFilledRoundRects());
  Serial.println(F("Done!"));
void loop(void) {
  for(uint8_t rotation=0; rotation<4; rotation++) {
    tft.setRotation(rotation);
    testText();
    delay(2000);
  tft.println(1234.56);
  tft.println();
  tft.setTextSize(5);
  tft.setTextSize(2);
  tft.setTextSize(1);
  int           x1, y1, x2, y2,
                w = tft.width(),
                h = tft.height();
  x1 = y1 = 0;
  y2    = h - 1;
  start = micros();
  for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
  x2    = w - 1;
  for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
  x1    = w - 1;
  y1    = 0;
  y2    = h - 1;
  start = micros();
  x2    = 0;
  x1    = 0;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = w - 1;
  x1    = w - 1;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = 0;
  start = micros();
  for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
  for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
  int           n, i, i2,
  start = micros();
  for(i=2; i<n; i+=6) {
    i2 = i / 2;
    tft.drawRect(cx-i2, cy-i2, i, i, color);
  int           n, i, i2,
  for(i=n; i>0; i-=6) {
    i2    = i / 2;
    start = micros();
    tft.fillRect(cx-i2, cy-i2, i, i, color1);
    tft.drawRect(cx-i2, cy-i2, i, i, color2);
  return t;
  start = micros();
  for(x=radius; x<w; x+=r2) {
    for(y=radius; y<h; y+=r2) {
  start = micros();
  for(x=0; x<w; x+=r2) {
    for(y=0; y<h; y+=r2) {
  n     = min(cx, cy);
  start = micros();
  for(i=0; i<n; i+=5) {
    tft.drawTriangle(
  start = micros();
  for(i=min(cx,cy); i>10; i-=5) {
    start = micros();
  return t;
  int           w, i, i2,
  start = micros();
  for(i=0; i<w; i+=6) {
    i2 = i / 2;
    tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 0, 0));
  int           i, i2,
  start = micros();
  for(i=min(tft.width(), tft.height()); i>20; i-=6) {
    i2 = i / 2;
    tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i, 0));
the ICs used is "SUM74HC245T"
Better pictures to read the numbers.
Sorry for the poor quality
this was the best i could get
and it reads
"SUM74HC245T
D1804A0PJ1"
I stumbled upon a similar issue... looks like a solution... using another library.
now i have tried the libraries given by 'gortyy' also uninstalled the newer version 2.3.3 and downloaded version 1. 8.19 to run those libraries, but still no improvement (same white screen and the brightness keeps adjusting)
any other solutions please..
Return the board..
