Actually , I got it to read on teensy,
I did not declared the union, I just used
void Enc_Calc_A(uint8_t motor_id)
{ Show_Inc_String ('A');
int64_t Enc_Read_2 = (int64_t)mybuffer_A[5] +
((int64_t)mybuffer_A[6] << 8) +
((int64_t)mybuffer_A[7] << 16) +
((int64_t)mybuffer_A[8] << 24) +
((int64_t)mybuffer_A[9] << 32) +
((int64_t)mybuffer_A[10] << 40) +
((int64_t)mybuffer_A[11] << 48) +
((int64_t)mybuffer_A[12] << 56);
long Enc_2 = Enc_Read_2;
Mot_Ang_Read [motor_id] = (360 * Enc_2) / 16383.00;
Serial.print("Enc2: ");
Serial.println(Enc_2);
Serial.print("Mot_Ang_Read deg: ");
Serial.println(Mot_Ang_Read [motor_id]);
I got excited when the numbers went up as I turned the shaft and became negative as I went CCW....
Then I applied the conversion to degrees, one full turn is 16383 pulses.
Then I realized that the numbers are wrong twice as high but not exactly twice.
Here is what I get after and approximate positive one turn of 360
A: BYTE 0:0 1:92 2:3 3:8 4:DB 5:2B 6:8C 7:0 8:0 9:0 10:0 11:0 12:0 13:B7 14:0 15:0 16:0 17:80
Enc2: 35883
Mot_Ang_Read deg: 788.49
Here how I process the incoming string:
if (Serial2.available()) { // for motors 12345
uint8_t b = Serial2.read(); // always read the next incoming byte
if (b == 0x3E) {
num_received_A = 0; // if begin of message, forget everything previously received
else { // we are done with the header
mybuffer_A[num_received_A + 1] = b; // otherwise, put the byte into the buffer
num_received_A ++;
//Serial.println (num_received_A);
if (num_received_A == (4 + mybuffer_A[3] ))// this is "message Complete" first four bytes + the Data Lenght
if (mybuffer_A[1] == 0x92 )
Enc_Calc_A(mybuffer_A[2]);
else if (mybuffer_A[1] == 0x9C)
{ ReadMot_Calc_A(mybuffer_A[2]);
// Show_Inc_String ('A');
else if (mybuffer_A[1] == 0x30 or mybuffer_A[1] == 0x31 or mybuffer_A[1] == 0x32) // 30 31 and 32 are pertaining to PID
{ Read_PID_Calc('A');
// Show_Inc_String ('B');
} // end of "if getting bytes in the array
// check if the buffer is full (shouldn't happen, right?)
if (num_received_A >= 20) {
num_received_A = 0; // discard everything
Serial.print(" Overflow A");
} // end of else iteration
} // end of ser available
The condition
applies to receiving this multi angle turn data, calling the function above.
What to do?
Thank you David,
