I use Arduino Nano, I provide source code as following:
by the way ,Is "Wire.write()" char array size 256?
This is Master
#include<Wire.h>
//#include <stdlib.h>
String cmd;
String PC_DevAddr;
String PC_RegAddr;
String PC_DataLength;
String PC_Data;
byte Output_U8_1D[256];
Wire.begin();//不指定 代表Master
Serial.setTimeout(5);
//Serial.println("I2C Master started");
//Serial.println("Try to send:Read:31,01,50");//DevAdr,RegAdr,Data length
if (Serial.available())
cmd= Serial.readString();
if(SearchStringBefore(cmd,"\r\n") == "Keyword not found!")
//Read:31,01,50
PC_DevAddr = SearchStringBefore(SearchStringAfter(cmd,"Read:"), "," );
PC_RegAddr = SearchStringBefore( SearchStringAfter(SearchStringAfter(cmd,"Read:"), "," ) , "," );
PC_DataLength = SearchStringBefore( SearchStringAfter( SearchStringAfter( SearchStringAfter(cmd,"Read:") , "," ) , "," ), "\r\n" );
/*Serial.println("PC Sent:");
Serial.println(cmd);
Serial.print("Dev Address:0x");
Serial.println(PC_DevAddr);
Serial.print("Reg Address:0x");
Serial.println(PC_RegAddr);
Serial.print("Data length:0d");
Serial.println(PC_DataLength.toInt());
requestFromSlave(byte(HexStrToU16(PC_DevAddr)),byte(HexStrToU16(PC_RegAddr)),PC_DataLength.toInt());//DevAdr,RegAdr,Data length
//requestFromSlave(byte(HexStrToU16(PC_DevAddr)),byte(HexStrToU16(PC_RegAddr)),HexStrToU16(PC_DataLength));//DevAdr,RegAdr,Data length
//delay(1000);
void requestFromSlave(byte DEV_ADR ,byte REG_ADR ,int DATA_LENGTH)
char U8array[DATA_LENGTH] = "";
Wire.beginTransmission(DEV_ADR);
Wire.write(REG_ADR);
Wire.endTransmission();
Wire.requestFrom(DEV_ADR, DATA_LENGTH);
//for(byte i=0;i<DATA_LENGTH;i++)
U8array *= Wire.read(); *
//Serial.print("Received DATA LENGTH:"); *
//Serial.println(sizeof(U8array)); *
Serial.println(U8array); *
//搜尋字串後面
String SearchStringAfter(String Source,String Keyword)
int SearchOutIndex; *
int Keyword_length;*
SearchOutIndex = Source.indexOf(Keyword);*
Keyword_length = Keyword.length();*
if(SearchOutIndex == -1)*
return "Keyword not found!";*
else*
return Source.substring(SearchOutIndex+Keyword.length());*
//搜尋字串前面
String SearchStringBefore(String Source,String Keyword)
else*
return Source.substring(0,SearchOutIndex);*
//Hex字串轉U16數字
*unsigned int HexStrToU16(String hexString) *
unsigned int decValue = 0;*
int nextInt;*
for (int i = 0; i < hexString.length(); i++) {*
nextInt = int(hexString.charAt(i));*
if (nextInt >= 48 && nextInt <= 57) nextInt = map(nextInt, 48, 57, 0, 9);*
if (nextInt >= 65 && nextInt <= 70) nextInt = map(nextInt, 65, 70, 10, 15);*
if (nextInt >= 97 && nextInt <= 102) nextInt = map(nextInt, 97, 102, 10, 15);*
nextInt = constrain(nextInt, 0, 15);*
_ decValue = (decValue * 16) + nextInt;_
return decValue;*
//Hex字串轉U8 array
int HexStrToU8array(String hexString)
int hexStringLen=0;*
hexStringLen = hexString.length();*
hexStringLen = hexStringLen/2; *
for(int i=0;i<hexStringLen;i++)*
Output_U8_1D = byte( HexStrToU16( hexString.substring(i2,i2+2) ) );
This is slave
#include<Wire.h>
#define I2C_SLAVE_ADDRESS 0x31
byte REG_ADR;
* ackToMaster(0x31); *
void ackToMaster(byte DEV_ADR)
* Wire.begin(DEV_ADR);//指定Address,代表Slave模式*
* Wire.onReceive(receiveEvent);//取得Reg Address*
* delay(0);*
* Wire.onRequest(requestEvent);//回饋Reg Address內容*
* delay(0);*
void receiveEvent(int howMany)
* REG_ADR = Wire.read();
//Serial.println(REG_ADR);
_}_
void requestEvent()
_{_
byte Data_0x01[30] = {0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x43,0x43,0x43,0x43,0x43,0x43,0x43,0x43,0x43,0x43};
byte Data_0x42[] = {0b11000011,0b00011101, 0xFF, 0xFF, 0xFF ,0xFF, 0x00, 0x00};
_ // 0-7 8-15 16-23 24-31 32-39 40-47 48-55 56-63*_
_ /_
_ StaticGridSts(0)_
_ DynamicGridSts(1) _
_ InternalErrorStatus(6)_
Communications_Timeout(7)
_ ExternalErrorStatus(8)_
_ ZoomViewResp(10-12)_
_ Data(16-47)_
_ /_
switch(REG_ADR)
* case 0x00:*
* Wire.write("Hello", 8);*
* break;*
* case 0x01:*
* Wire.write("00000000001111111111000000000011",32);*
* break;*
* case 0x08:*
* Wire.write("this is ", 9);*
* break;*
* case 0x10:*
* Wire.write("I2C test", 8);*
* break;*
* case 0x42:*
* Wire.write(Data_0x42, 8);
_ break;_
_ }_
_}*_
