Hi
I did that many time before but this time is not working, what I forgot ?
#include "EmonLib.h"
EnergyMonitor emon1;
int aread, newread;
emon1.current(0, 111.1);// Current: input pin A1, calibration.
double Irms = emon1.calcIrms(1480); // Calculate Irms only
//newread = analogRead(A0);
newread = Irms;
if (newread > aread + 20 || newread < aread - 20 ) aread = newread;
Serial.print(Irms * 1000); // Irms
Serial.print(" average ");
Serial.println(aread * 1000); // average
Because (newread > aread + 20 || newread < aread - 20 ) always evaluates to false (for whatever reason).
If you put some more print statements in, you might be able to find it.
newread = Irms;
Serial.print(F("Irms = ")); Serial.println(Irms);
Serial.print(F("aread = ")); Serial.println(aread);
Serial.print(F("newread = ")); Serial.println(newread);
Serial.println(F"(adjusting aread")):
aread = newread;
J-M-L
May 30, 2022, 4:18am
3
And else what is aread Value? The default one for global variables is 0
Also are you sure about 0 meaning A1?
J-M-L
May 30, 2022, 4:31am
5
Make sure you connected to the right pin, could possibly explain why the value did not change
I'm trying to adopt this program for Irms
int aread, newread;
if (newread > aread +2 || newread < aread -2 ) aread=newread;
Serial.print(newread);
Serial.print(" newread ");
Serial.println(aread+1);
newread = Irms;
J-M-L
May 30, 2022, 4:38am
7
Yes we understand what you are trying to do and the code is OK
Your challenge is that the condition is such that you never make it through the if() and so the value never changes apparently as explained by @sterretje . Try his code
J-M-L
May 30, 2022, 5:00am
9
Newread and aread are int so they loose the decimal part of the double
tom321
May 30, 2022, 5:18am
10
So I multiplied everything by 1000
//int aread, newread;
float aread, newread;
emon1.current(0, 111.1);// Current: input pin A0, calibration.
int F;
newread = Irms;
Serial.print(F("Irms = ")); Serial.print(Irms*1000);// 0k
Serial.print(F(" aread = ")); Serial.print(aread*1000);// = 0
Serial.print(F(" newread = ")); Serial.print(newread*1000);// Ok
Serial.print (F(" adjusting aread "));
aread = newread;
Serial.print( " Irms * 1000 = ");
Serial.print( Irms * 1000); // Irms
Serial.println(aread * 1000); // average = 0
You want to see the values, not the values multipled by 1000.
Irms is 0.24058 and aread is zero so your condition will be false; the difference is 0.24058 which is smaller than 20.
tom321
May 30, 2022, 12:47pm
12
sterretje:
multipled by 1000.
I multiply by 1000 to have numbers higher than 0.
sterretje:
aread is zero
That is the name of the topic = why ?
and how to fix it,
Doesn't matter as long as aread is not a zero
Let me try again.
newread equals 0.24058. Initially aread equals zero. So newread is smaller that 0 plus 20 and the first part of the condition is false. newread is also greater than 0 minus 20 so the second part of the condition is also false. And hence you will never see "adjusting read" and aread will not be updated.
tom321
May 30, 2022, 2:34pm
14
I did this way , I have some numbers instead of 0, testing
double Irms2 = Irms*1000;
newread = Irms2;
Serial.print(F("Irms2 = ")); Serial.print(Irms2);// 0k
tom321
May 30, 2022, 3:16pm
15
the results, aread = average= not good
int F;
newread = Irms2;
//if (newread > aread + 0.1 || newread < aread - 0.1 )
aread = newread;
// Serial.print( " Irms * 1000 = ");
// Serial.print( Irms * 1000); // Irms
Please explain that. If you are trying to calculate an average, your approach is wrong.
tom321
May 30, 2022, 4:38pm
17
This is a program with nice averaging - green line
And this is AC voltmeter with lot of noise,
The goal is to apply the first program to AC voltmeter.
