Why did this led turn on
this led lit up after a while of this code running, what is it for?`
#include <SD.h>// mosi = 11//miso = 12//clk = 13//cs = 10
#include <SPI.h>
#include <virtuabotixRTC.h> //https://github.com/chrisfryer78/ArduinoRTClibrary/tree/master
virtuabotixRTC myRTC (6, 7, 8); //clk, data, rst
  //sec, min, day of week, day of month, month, year
  //myRTC.setDS1302Time(00, 21, 15, 4, 1, 8, 2024); if battery inserted you have need to set same time every start of arduino
  while (!Serial);
  Serial.print("SD Ready");
  if (!SD.begin(10)) {
    Serial.println("SD Card Failed");
    return;
  Serial.println("SD Good");
  Serial.end(); // no serial need, only for start
  const int Period = 1000; // millisec between readings
  const byte Num = 10; // how much lines collect before store to SD
  static char Text[Num ][30]; // i am not sure if attribut static is really need
  static byte index = 0;
  static unsigned long oldMillis = millis();
  if (millis() - oldMillis >= Period ) {
    oldMillis += Period ;
    myRTC.updateTime();
    int readA0 = analogRead(A0);
    sprintf(Text[index], "%02u/%02u/%02u %02u:%02u:%02u\t%u\n", myRTC.year, myRTC.month, myRTC.dayofmonth, myRTC.hours, myRTC.minutes, myRTC.seconds, readA0);
    index++;
    if (index == Num ) {
      index = 0;
      File myFile = SD.open("lightS" + String(myRTC.hours % 6), FILE_WRITE); // 6 files total
      for (int i = 0; i < Num ; i++) myFile.print(Text[i]);
      myFile.close();
you are using SPI.
SPI uses 13 for clk
the build in led is also connected to 13.
Therefore the LED lights up when SPI is used.
Why not light up immediately though? It was running or an hour or two before lighting up
Hi, @jake1078469
Is this associated with this;
Tom... :smiley: :+1: :coffee: :australia:
https://wiki.keyestudio.com/Ks0001_keyestudio_UNO_R3_BOARD
No, I just noticed the led turning on and was wondering why. Is it a problem indicator?
