UKHeliBob:
Check the syntax of the if statement
I know that problem is there but don't know how to fix it
UKHeliBob:
I was referring to this line of code whuch was in one version of your code
if Irms (> 0.5)
It may not be in later versions but the syntax is/was wrong
AWOL:
volt = analogRead(PA7); // A0
if (volt > 0.5)
analogRead returns a positive integer value. Only one positive integer value (debatable) is less than 0.5.
float volt = analogRead(PA7);
volt = (volt * 3.3) / 4095.0; = this volt I want to be used, I thought I using
A Big Thanks all of you = I did it.
// volt = analogRead(PA7);
if (digitalRead(PB9) == HIGH)
if (volt > 0.5)
//if (volt > 5)
// if (volt < 0.5)
//if (i < 35)
i++;
// delay (300);
i--;
//delay (300);
// float volt = analogRead(PA7);
// volt = (volt * 3.3) / 4095.0;
lcd.setCursor(0, 0);
lcd.print("V=");
lcd.print(volt);
lcd.setCursor(0, 1);
lcd.print("I=");
lcd.print( i);
//delay (100);
read again #2
AWOL
Now can be marked SOLVED
Thanks
Now I am back to original code with AC Voltmeter, it is working Ok for designated voltage.
I want the program to tune to minimum of Irms. I think this line's need work.
I will try any suggestion.
previousIrms = currentIrms; // store what was read last time
// currentIrms = analogRead(PA7); // get a new reading
//currentIrms = ?? ??
//currentIrms = float Irms = emon1.Irms; = not good
the program
HardwareTimer pwmtimer4(4);
#include "EmonLib.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
EnergyMonitor emon1;
float cur, acur[50], sumc;
int i = 0;
int ovfi = 0;
int (Irms) = 0 ;
int currentIrms = 0;
int previousIrms = 0;
int maxIrms = 0;
int minIrms = 4095.0;
pwmtimer4.pause();
pwmtimer4.setPrescaleFactor(3);
pwmtimer4.setOverflow(2000);
//pwmtimer4.setCompare(TIMER_CH2, 2880);
pwmtimer4.refresh();
pwmtimer4.resume();
pinMode(PB7, PWM); //duty regulated for balance
pinMode(PB9, INPUT_PULLDOWN);
pinMode(PA7, INPUT); // Irms
lcd.begin(16, 2);
emon1.current(PA7, 2.8);
pwmtimer4.setCompare(TIMER_CH2, i);
emon1.calcVI(20, 2);
//if (Irms > 0.5)
if (previousIrms < currentIrms)
i++;
i--;
lcd.print("V=");
lcd.print(Irms);
lcd.print("I=");
lcd.print( i);
//delay (50);
int (Irms) = 0 ; Why still?
You've got a float called Irms.
Before was int (Irms) ; and voltmeter was working Ok, I will change that.
Vik321:
Why? (There) (is) (not) (a) (reason) (on) (earth) (why) Irms, (whatever) (the) (type), (needs) (to) (be) (in) (parentheses).
Thanks for pointing that, the brackets are leftovers from another declarations = fixed
I did some testings on designated voltage of Irms, it is working Ok down to 0.01 V after that else part is not working, i should bounce around 65 (65 +/-1) but is missing this point and is rising as long as button is hold.
Any ideas how to improve reliability of else part ?
if (Irms > 0.03) //0.09=i=95=V 0.1_ 0.05=i=62 V=0.06, _0.03=i= missing 0.03V
i++;
i--;
Can we get a translation of that comment, please?
for designated voltage 0.09V i =95, for designated voltage 0.05V i = 62, for designated voltage 0.03 V i is missing designated voltage and is continue to rising. Reliable designated voltage is 0.01V, lower than that = else part is not working.
i--;
correction 0.1
typing error should be 0.01.
I wish I hadn't asked now.
I'm even more confused.
Can we see all of your code, please?
Post #46
Where do you set currentIrms in your code in #46?
christop:
That's the reason I wanted to see the current code
The second part = program
Here is again
int i ;
int ovfi;
//int (Irms) = 0 ;
int Irms ;
int currentIrms ;
int previousIrms ;
//int maxIrms ;
//int currentIrms = 0;
//int previousIrms = 0;
int maxIrms = 0;
pwmtimer4.pause();
pwmtimer4.resume();
lcd.begin(16, 2);
ovfi = 100 - i;
// if ( i > 0) {
// i++;
//previousIrms = currentIrms; // store what was read last time
// currentIrms = Irms;
// minIrms = Irms;
if (Irms > 0.05) //0.09=i=95=V 0.1_ 0.05=i=62 V=0.06, _0.03=i= missing 0.03V
//0.08ok,
//if (Irms < minIrms)
// if (previousIrms < currentIrms)
// if (previousIrms > currentIrms)
i++;
delay (100);
i--;
delay (100);
lcd.print("V=");
lcd.print(Irms);
lcd.print("I=");
lcd.print( i);
//delay (50);
