Being inspired by a post in this Forum, I have explored a bit to understand the behavior of pointer variable referring to Fig-1. Unfortunately, my following sketch does not work to produce the expected result when ptr = &data2; code is replaced by ptr--;
int data1 = 0x1234; //data are saved in decreasing RAM memory locations
int data2 = 0xABCD;
int *ptr; //pointer variable ptr holds address of a word-wide location
ptr = &data1; //ptr holds address of data1
Serial.println((unsigned int)ptr, HEX); //shows: address of data1: 08FA
int rdData1 = *ptr;
Serial.println((unsigned int)rdData1, HEX); //shows: 1234
ptr--;//ptr = &data2; //ptr holds address of data2
Serial.println((unsigned int)ptr, HEX); //shows:address of data2: 08F8
int rdData2 = *ptr;
Serial.println((unsigned int)rdData2, HEX); //does not show: ABCD
You cannot assume any particular order for two separate variables, unless you have very deep knowledge of the exact allocation methods used in the compiler/linker.
If you had made an array of int, then you could use increment/decrement, or any other valid arithmetic, for a pointer within the array, but not to any variable declared separately.
Whether the processor is little or big endian is not relevant to the order in which two separate variables are stored.
The originally posted code (with the line ptr--;) does in fact give the result that you expected, when compiled and run on a Pro Mini. But you should not make any assumptions about the order in which independent variables are stored in memory.
The placement of the variables is going to be dependent on the compiler used, which verison of the compiler is being used, the various optimizations used, the linker, as well as the processor that sketch is running on. If you intentionally declared a 16-bit integer on an ESP32 it could be aligned on a 32-bit boundary and completely throw off the increment/decrement, since there would be unused space between the variables.
Assuming any relative positioning between two separately declared variables definitely falls under "undefined behavior".
That means that the memory map of Fig-1 of post #1 is NOT authentic anyway to place data in the memory locations the way it has been shown.
Declaring an array like int myData = {0xABCD, 0x1234}; is, for sure, going to place the data1 and data2 in adjacent memory locations. This will make my sketch working with ptr-- and yes, it works. Output:
8FA
1234
8F8
ABCD
Now, the memory map and arithmetic operation on pointer variable are valid when the data items are guaranteed to be in adjacent memory locations.
This is the output of the original sketch of post #1; where, the memory map shows that the data are in adjacent memory locations. As I have understood from various posts of the thread that seperately declared data items might be placed at different locations during run-time.
8FA
1234
8F8
F002
post #15@david_2018 has said that an array will ensure the placement of data items in adjacent memory locations. Based on this statement I have said that my sketch is going to work.
