Hello, currently trying to implement a watchdog into my project. I am using the WDTZero library for controlling the watchdog on my MKR NB 1500. The program is trying to measure data, send it to a server, go to sleep, wake up, and repeat the process. Sometimes the code can hang if it can't connect to the NTP server or the server on which the data is being stored, I want the watchdog to reset the program in cases in which this happens.
A sketch of the program is below. The reason why the NB network is often after different connections is that the NB 1500 is not able to connect to another server if the GPRS connection is already open, so I always reset it before trying another connection.
setup_watchdog(); //Sets up the watchdog timer
connect_GPRS_NB(); //Connects to the NB network and opens a GPRS connection
request_NTP(); //Requests epoch1970 from the NTP server and then closes the connection
timezone_adjustment(); //Adjusts the epoch time to my timezone (in Norway)
set_RTC(); //Activates the SAMD21 RTC with this timezone adjusted time
disconnect_NB(); //Disconnects from the NB network
delay(2000);
MyWatchDoggy.clear(); //Resets the watchdog timer
get_ENV_data(); //Takes measurements using the MKR NB ENV shield
connect_to_server(); //Connects to the server in which the data will be stored
write_to_server(); //Writes the data on the server
disconnect_from_server(); //Disconnects from the server
LowPower.deepSleep(300000); //Goes to deep sleep for 5 minutes
delay(3000);
All the functions above are written in other .cpp files and imported thru header files into the main file. Here is the code for activating and configuring the watchdog:
#include "watchdog.hpp"
#include "GPRS_NB_connection.hpp"
WDTZero MyWatchDoggy;
void setup_watchdog()
MyWatchDoggy.attachShutdown(NVIC_SystemReset); //calls reset function
MyWatchDoggy.setup(WDT_SOFTCYCLE8M); //8 minute watchdog timer
The program works fine in the way described at the top of the post when the watchdog is not included. But when including the watchdog, it bites after 30 seconds when the dog only should have bit after 8 minutes. I see this because data is being sent about every 25-30 seconds to the server.
At first, I thought I had not activated the watchdog in the right way, so I wrote another program to test it:
#include <Arduino.h>
#include <WDTZero.h>
#include <RTCZero.h>
RTCZero rtc;
void set_RTC()
rtc.begin();
rtc.setYear(0);
rtc.setMonth(0);
rtc.setDay(0);
rtc.setHours(0);
rtc.setMinutes(0);
rtc.setSeconds(0);
void shutdown()
Serial.println("Shutting down");
while (!Serial)
Serial.println("Starting up Arduino");
MyWatchDoggy.attachShutdown(shutdown);
set_RTC();
Serial.print(rtc.getMinutes());
Serial.print("/");
Serial.print(rtc.getSeconds());
Serial.println("");
But in this program the watchdog bites after about 8 minutes as it should.
I have not included the code for the functions described in the first code since I know they work without the watchdog and the code itself is very long. But if you think the problem could be caused by these functions for some reason, I will edit the post and include all the function codes.
