Why Serial Monitor shows double "Getting your variable"?
Team,
Why Serial Monitor shows double “Getting your variable” which is triggering “Gatekeeper test if”?
Getting your variable:
Value: 1.00
Value: 1.00
    float value = client.getValue(ID);
    delay(100);
    Serial.print("Value: ");  //
    Serial.println(value);
  if (value == 1.00)  {  // Gotcha command from Google home
digitalWrite(garage,value);   // Change pin value - Switch relay on and off
delay(700); // Press and hold garage button for X sec
digitalWrite(garage,0);
     delay(20000); // Wait until door closed 20 sec.
float value=0.00;
client.add(ID, 0.00);  // Sending back to Ubidots value 0
client.sendAll(false);
   delay(100);
// gatekeeper test
  if (currentMillis - previousMillis <= interval) {
    previousMillis = currentMillis;   // save the last time value=0.00;
     Serial.print("Hacked!!!");
    delay(1800000);
because you are printing it twice?
Yeah . . . . have you bothered to read your own code? Even if it isn't yours, you should at least bother to read what you copy/pasted.
Read it line by line. Start from the top. Every time you see "Serial.print", drink. Repeat until you figure it out or stop caring.
UGH... You are right guys. :o
But my main concern was Why it's triggering"Gatekeeper test IF"?
When actually only once "Value: 1.00" appear after first IF.
That is NOT what that code is doing. If you used some meaningful names for now and then, you’d learn that it is no mystery WHEN you need to assign a value to the then variable, and you’d KNOW that that comment is nonsense.
