Why the color stays on red(rgb led)
im trying to smoothly turn an rgb led red and smoothly make it white and it doesnt work . heres the code and schem
// C++ code
int LRGB_RED=11;
int LRGB_GREEN=9;
int LRGB_BLUE=10;
int i=0;
pinMode(LRGB_RED,OUTPUT);
pinMode(LRGB_GREEN,OUTPUT);
pinMode(LRGB_BLUE,OUTPUT);
  while(i<255) {
    rgbled(i,0,0,0);
    i++;
    delay(100);
   while(i>0) {
    rgbled(i,0,0,0);
    i=i-1;
    delay(100);
void rgbled(int RED,int GREEN,int BLUE,int FADE){
  digitalWrite(LRGB_RED, RED-FADE);
  digitalWrite(LRGB_GREEN, GREEN-FADE);
  digitalWrite(LRGB_BLUE, BLUE-FADE);
use three resistors, one per LED
(and look at the parameters for your call to rgbled())
You appear to be only controlling the red LED.
ok ill try
I'm still struggling with the concept of "smooth" and "digitalWrite"
Try this way ---->>>> rgbled(0,0,0,i);
RV mineirin
smooth isnt a part of the code
so it's part of the goal...
i mean slowly increase the brightness of red led and slowly decrasse it
if you use only the red led out of the 3, one Resistor is enough
use analogWrite() instead of digitalWrite() and of course a PWM capable pin
so i have to connect the wires to analog pins?
that worked but it instantly turns white and slowly gets red
int LRGB_RED=A0;
int LRGB_GREEN=9;
int LRGB_BLUE=10;
int i=0;
  while(i<255) {
    rgbled(i,0,0,0);
    i++;
    delay(10);
   while(i>0) {
    rgbled(i,0,0,00);
    i=i-1;
    delay(10);
No, PWM pins
i did but it didnt work i connected them to analog pins it worked
i think thi is a math problem here that a dumb like me cant solve
 while(i<255) {
    rgbled(i,0,0,0);
    i++;
    delay(10);
   while(i>0) {
    rgbled(i,0,0,00);
    i=i-1;
    delay(10);
We can't help you solve anything if you don't post code
In this bit of code you are digitalWrite expecting PWM.
Try using analogWrite.
  analogWrite(LRGB_RED, RED-FADE);
  analogWrite(LRGB_GREEN, GREEN-FADE);
  analogWrite(LRGB_BLUE, BLUE-FADE);
This may help.
When you have editred your code please post it again in a new post please.
Tom... :grinning: :+1: :coffee: :australia:
// C++ code
int LRGB_RED=A0;
int LRGB_GREEN=9;
int LRGB_BLUE=10;
int i=0;
  while(i<255) {
    rgbled(i,0,0,0);
    i++;
    delay(10);
   while(i>0) {
    rgbled(i,0,0,00);
    i=i-1;
    delay(10);
Anything minus zero is . . ?
A0 is not a PWM pin.
i fixed that and it
worked
