Why the "while" do not work ? the things inside happens but my servo turn after (I want him to stay until I repush on the pressure detector)
#define capteur_force A0 // broche capteur de force
#include "Servo.h"
Servo servo; // création de l'objet "servo"
  Serial.begin(9600); // Initialisation du moniteur serie
  servo.attach(9); // attache le servo au pin spécifié
  int force = analogRead(capteur_force); // on lit la valeur venant du capteur de force
  Serial.print(force);
  if(force > 400){
    servo.write(90);
    delay(2000);
    while(force < 400){
      delay(1);
  else{
    servo.write(25);
  delay(200);
I'm french so "capteur force" mean pressure detector and force still forceTexte préformaté
Every time you create a new local variable with the name "force", your code uses the most recent variable with that name. Use a SINGLE variable that is global.
This is an interesting bug.
Let’s assume that the force value read right when the loop starts is > 400. The if is executed, the servo moves to position 90, and waits 2 seconds. The value of force is still >400, so the while is not executed.
After the if, we wait for another 200msec.
The loop then restarts.
Now let’s assume that the force detected is not >400. The else executes moving the servo to position 25. Wait for 200msec and restart loop.
Besides the effect mentioned by @Paul_KD7HB, the while will never execute.
Try changing to
and how can I change it ?
I had the delay of 2 secondes for release the pressure detector so force is (close) equal to 0 and the loop work until I press it again but it continue.
The while() is using the previously defined "force", then the analogRead is using the newly created variable name "force". You have to learn the difference between global and local variables and see why using the same name for both is a disaster waiting to happen.
Hi @taaniyu
welcome to the arduino-forum.
You should write in normal words what the wanted functionality is.
This description shall avoid all programming-terms because there might be a mis-conception about how a certain detail of programming works.
With normal words you are an expert in french.
So I recommend that you write this description in french and then let do google-translate the translation to english.
As long as it is unclear what functionality you want almost any suggestion might be wrong.
Give this Code-Version a try. The variable "force" is made global. This means at all places in your code the same variable is used.
This code-version has additional serial printing to make visible what your code is really doing
// MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START *
// a detailed explanation how these macros work is given in this tutorial
// https://forum.arduino.cc/t/comfortable-serial-debug-output-short-to-write-fixed-text-name-and-content-of-any-variable-code-example/888298
#define dbg(myFixedText, variableName) \
  Serial.print( F(#myFixedText " "  #variableName"=") ); \
  Serial.println(variableName);
#define dbgi(myFixedText, variableName,timeInterval) \
    static unsigned long intervalStartTime; \
    if ( millis() - intervalStartTime >= timeInterval ){ \
      intervalStartTime = millis(); \
      Serial.println(variableName); \
#define dbgc(myFixedText, variableName) \
    static long lastState; \
    if ( lastState != variableName ){ \
      Serial.print( F(#myFixedText " "  #variableName" changed from ") ); \
      Serial.print(lastState); \
      Serial.print( F(" to ") ); \
      lastState = variableName; \
#define dbgcf(myFixedText, variableName) \
    static float lastState; \
// MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END *
#include "Servo.h"
int force;
  //Serial.print(force);
  dbgc("ToL", force);
  if (force > 400) {
    Serial.println("force > 400 => servo.write(90)");
    servo.write(90);
    delay(2000);
    Serial.println("delay(2000) finished");
    while (force < 400) {
      dbgc("while", force);
      delay(1);
  else {
    Serial.println("else force BIGGER than 400");
    servo.write(25);
  delay(250);
  Serial.println("delay(250) finished");
best regards Stefan
thank you very much
When force is > 400 it will go inside the if but the while will never execute.
There is a function-call to servo-write and delay()
This could cause the servo to move and can cause a change of the measured value
This is another reason why it is so important to describe your wanted functionality in normal words
and
describe how your device works
best regards Stefan
Don't worry I just understand variables
here's the code working (and translate)
#define pressure_detector A0 // pin of the pressure detector
#include "Servo.h"
Servo servo;
  int forceLoc;
  servo.attach(9);
  int force = analogRead(pressure_detector);
  if(force > 400){
    servo.write(90);
    delay(1500);
    while(force < 400){
      delay(200);
    servo.write(25);
too poor english I'm out
When the value of variable force is > 400 the execution flow enters the if. When it gets to the while its value has not been modified and is still > 400 so the while does not execute.
The while condition is wrong.
  if(force > 400){ // force is bigger than 400
    servo.write(90); // execute a servo-command
    // that CHANGES the PHYSICAL force
    delay(1500); // WAIT 1,5 seconds to let the servo do its move
    // read in measured force NEW
    force = analogRead(pressure_detector);     // read in measured force NEW
   // because value was read in NEW force CAN be smaller than 400
   // CAUSED through the servo-MOVE
    while(force < 400){
      delay(200);
[/quote]
what else do you need to understand it?
You understand my post #11 refers to the code inPost #10, right?
