So, I'm new to programming (but having fun). I have written the following code but when I run it and send the ASCII characters to toggle an output (which is used to turn a relay on or off), it switches the output on for approx. one second and then it always clicks back to off. I want the relay, when the ASCII is received, to switch states and hold it's position there until the same ASCII message is received. I don't know that it matters but, I'm using a Fundamental Logic MaxSerial board (Diecimila).
int Pin0 = 0; // Relay Pins and LED test on 13
int Pin1 = 1;
int Pin2 = 2;
int Pin3 = 3;
int Pin4 = 4;
int Pin5 = 5;
int Pin6 = 6;
int Pin7 = 7;
int Pin8 = 8;
int Pin9 = 9;
int Pin10 = 10;
int Pin11 = 11;
int Pin12 = 12;
int ledPin = 13;
int Pin14 = 14;
int Pin15 = 15;
int Pin16 = 16;
int incomingCommand = 0; //holding variable for strings
void setup() // run once, when the sketch starts
pinMode(Pin0, OUTPUT); // sets the digital pins as outputs
pinMode(Pin1, OUTPUT);
pinMode(Pin2, OUTPUT);
pinMode(Pin3, OUTPUT);
pinMode(Pin4, OUTPUT);
pinMode(Pin5, OUTPUT);
pinMode(Pin6, OUTPUT);
pinMode(Pin7, OUTPUT);
pinMode(Pin8, OUTPUT);
pinMode(Pin9, OUTPUT);
pinMode(Pin10, OUTPUT);
pinMode(Pin11, OUTPUT);
pinMode(Pin12, OUTPUT);
pinMode(ledPin, OUTPUT);
pinMode(Pin14, OUTPUT);
pinMode(Pin15, OUTPUT);
pinMode(Pin16, OUTPUT);
void loop(){
if (Serial.available() > 0) {
digitalWrite (ledPin, HIGH); //turn LED on when serial incoming
incomingCommand = Serial.read();
else {
digitalWrite (ledPin, LOW); //turn it off when no serial available
if (incomingCommand == 00)
while(Pin0 == true){
digitalWrite(Pin0, LOW);
else{
digitalWrite(Pin0, HIGH);
if (incomingCommand == 01)
while(Pin1 = true){
digitalWrite(Pin1, LOW);
else{
digitalWrite(Pin1, HIGH);
if (incomingCommand == 02)
while(Pin2 = true){
digitalWrite(Pin2, LOW);
else{
digitalWrite(Pin2, HIGH);
if (incomingCommand == 03)
while(Pin3 = true){
digitalWrite(Pin3, LOW);
else{
digitalWrite(Pin3, HIGH);
if (incomingCommand == 04)
while(Pin4 = true){
digitalWrite(Pin4, LOW);
else{
digitalWrite(Pin4, HIGH);
if (incomingCommand == 05)
while(Pin5 = true){
digitalWrite(Pin5, LOW);
else{
digitalWrite(Pin5, HIGH);
if (incomingCommand == 06)
while(Pin6 = true){
digitalWrite(Pin6, LOW);
else{
digitalWrite(Pin6, HIGH);
if (incomingCommand == 07)
while(Pin7 = true){
digitalWrite(Pin7, LOW);
else{
digitalWrite(Pin7, HIGH);
if (incomingCommand == 18)
while(Pin8 = true){
digitalWrite(Pin8, LOW);
else{
digitalWrite(Pin8, HIGH);
if (incomingCommand == 19)
while(Pin9 = true){
digitalWrite(Pin9, LOW);
else{
digitalWrite(Pin9, HIGH);
if (incomingCommand == 10)
while(Pin10 = true){
digitalWrite(Pin10, LOW);
else{
digitalWrite(Pin10, HIGH);
if (incomingCommand == 11)
while(Pin11 = true){
digitalWrite(Pin11, LOW);
else{
digitalWrite(Pin11, HIGH);
if (incomingCommand == 12)
while(Pin12 = true){
digitalWrite(Pin12, LOW);
else{
digitalWrite(Pin12, HIGH);
if (incomingCommand = 14)
while(Pin14 = true){
digitalWrite(Pin14, LOW);
else{
digitalWrite(Pin14, HIGH);
if (incomingCommand == 15)
while(Pin15 = true){
digitalWrite(Pin15, LOW);
else{
digitalWrite(Pin15, HIGH);
if (incomingCommand == 16)
while(Pin16 = true){
digitalWrite(Pin16, LOW);
else{
digitalWrite(Pin16, HIGH);
