Hey,
I am currently working on an LED strip project. I have a boring closet with open cabinets that I want to pimp with an LED strip that I can control with my smartphone.
I bought an esp8266 esp-01 to connect to my arduino Mega, which is connected to the led strip. The code I am now using, is a code I found online however it doesn’t really do exactly what I want and can’t seem to fix it. I want to be able to enter my IP address together with a command via a URL and then have the arduino read the Serial monitor and have it know what to do. However right now it saves the incoming command in a string variable and than I use indexOf() to find that command in that string. If it is found an if statement makes sure that the command is executed.
#define DELAY 5000 // mS
#define LED 3
const byte button = 53;
int button_state = 0;
int state;
pinMode(LED,OUTPUT);
pinMode(button,INPUT);
Serial1.begin(115200);
SendCommand("AT+RST", "Ready");
delay(DELAY);
SendCommand("AT+CWMODE=1","OK");
SendCommand("AT+CIFSR", "OK");
SendCommand("AT+CIPMUX=1","OK");
SendCommand("AT+CIPSERVER=1,80","OK");
void loop(){
button_state = digitalRead(button);
if(button_state == HIGH){
Serial1.println("AT+CIPSEND=0,23");
Serial1.println("<h1>Button was pressed!</h1>");
SendCommand("AT+CIPCLOSE=0","OK");
String IncomingString="";
boolean StringReady = false;
while (Serial1.available())
IncomingString=Serial1.readString();
StringReady= true;
if (StringReady){
Serial.println("Received String: " + IncomingString);
if (IncomingString.indexOf("LED=1") != -1) {
state = 1;
if (IncomingString.indexOf("LED=2") != -1) {
state = 2;
if (IncomingString.indexOf("LED=3") != -1) {
state = 3;
if (IncomingString.indexOf("LED=4") != -1) {
state = 4;
switch(state)
case 2:
pulse();
case 1:
analogWrite(LED,49);
case 3:
analogWrite(LED,255);
case 4:
analogWrite(LED,230);
boolean SendCommand(String command, String response)
Serial1.println(command); // Send "AT+" command to module
if (!echoFind(response))// timed out waiting for response string
return true; // response found
boolean echoFind(String keyword){
byte current_char = 0;
byte keyword_length = keyword.length();
long deadline = millis() + DELAY;
while(millis() < deadline) //set a timer of 5 seconds. If no response within 5 seconds end function
if (Serial1.available()) //if Serial1.available == true
char ch = Serial1.read();
Serial.write(ch);
if (ch == keyword[current_char])
if (++current_char == keyword_length){
return true;
return false; // Timed out
void pulse()
for(int i = 0; i < 255; i++)
analogWrite(LED, i);
delay(50);
if (Serial1.available()) break;
for(int i = 255; i > 0; i--)
analogWrite(LED,i);
delay(50);
So if I enter “[IP-address]/LED=1” the entire text that comes in (it includes some random stuff I don’t understand) is saved in IncomingString. Then with indexOf() it searches IncomingString for a known command, in this case it will find “LED=1” and start the programm associated with LED=1. However I want to send for example RGB values. However if I were to do that in the same way I’d need 255 if statements for R, B and G. That sounds like the worst possible code ever.
Does anyone know how to write this code better?
Thanks in advance
