Wifi ESP8266 with arduino to transmit data to smartphone
Good Afternoon,
I have connect ESP8266 to arduino and I have created an app with "app inventor" tool to transmit data to arduino and it works. Now I want to receive data from arduino but it doesn't work.
First of all
I have connected ESP8266 to Arduino pin 6 and 7 and by using the library SoftwareSerial I have configured, with AT commands, the ESP8266 as a PC server, connected to my wifi, with static IP.
In app on smartphone I have used an external Client component that open connection with the specific IP of ESP8266 on port 333.
Then I use the Client component command to send a word and by using the "read" function of SoftwareSerial I can read the received data from ESP8266, and it works!!
Now I would send something to my app from Arduino and ESP8266 but When I use the AT+CIPSTATUS? to verify the connection the ESP8266 answer is "ERROR".
Anyway I try to send a char with the following commands
TCPSerial.println("AT+CIPSEND=2");
delay("1000");
TCPSerial.println("a");
But I don't receive anything on my app.
Moreover if in Arduino I send the command
TCPSerial.println("AT+CIPCLOSE");
I can send always data from my app so the connection is still up.
So my question is
How can I send data from arduino to my app, by using AT commands, if the connection is open by the client on my APP?
I send the pic of application and complete arduino code
Thanks a lot for any suggestion
#include <SoftwareSerial.h>
#include <TimerOne.h>
SoftwareSerial TCPSerial(6,7); // RX, TX
String messaggio;
int checkOK=0;
char psw[40];
int cerca=1;
char data[40];
char data2[80];
String compare;
volatile int count=0;
void TSC_Callback(){
  count=count+1;
  if (count>1200) {count=0;
  configurazione();
void configurazione() {
  checkOK=0;
  Serial.println("passo0");
  for(int i=0;i<40;i++){data[i]=" ";}
  while(checkOK==0){
  TCPSerial.println("AT+CWMODE_CUR=1");//configura la scheda come Computer
  if(TCPSerial.available()){  for(int i=0;i<40;i++){data[i]= TCPSerial.read();Serial.print(data[i]);}}
  compare=String(data);
  Serial.println(compare);
  if(compare.indexOf("OK")!=-1)checkOK=1;
Serial.println("passo1");
  for(int i=0;i<80;i++){data2[i]=" ";}
  checkOK=0;
  while(checkOK==0){
    TCPSerial.println("AT+CWJAP_DEF=\"air2bite_MV\",\"114121641\",\"e4:aa:55:55:55:55\"");
     delay(10000);
    if(TCPSerial.available()){  for(int i=0;i<80;i++){data2[i]= TCPSerial.read();}}
  compare=String(data2);
  if(compare.indexOf("178721747")!=-1)checkOK=1;
Serial.println("passo2");
  checkOK=0;
  while(checkOK==0){
    TCPSerial.println("AT+CIPMUX=1");
   if(TCPSerial.available()){  for(int i=0;i<40;i++){data[i]= TCPSerial.read();}}
  Serial.println("passo3");
  checkOK=0;
  while(checkOK==0){
    //configura la scheda come TCP server
    TCPSerial.println("AT+CIPSERVER=1");
Serial.println("passo4");
  checkOK=0;
  while(checkOK==0){
    //configura l'indirizzo IP statico
    TCPSerial.println("AT+CIPSTA_CUR=\"192.168.159.199\",\"192.168.159.1\",\"255.255.255.0\"");
  if(compare.indexOf("192.168.159.199")!=-1)checkOK=1;
Serial.println("passo5");
  checkOK=0;
  while(checkOK==0){
    TCPSerial.println("AT+CIPSTO=30");
TCPSerial.begin(9600);
configurazione();
cerca=1;
while(cerca){
for(int i=0;i<40;i++){ data[i]=" ";}
      data[0]= TCPSerial.read();
 messaggio=String(data);
if((messaggio.indexOf("c")!=-1)or(messaggio.indexOf("p")!=-1))
    for(int i=1;i<15;i++){
  if((compare.indexOf("cancello")!=-1)or(compare.indexOf("porta")!=-1))
    cerca=0;
    //Serial.print(compare);
if(compare.indexOf("cancello")!=-1)
  digitalWrite(8,HIGH);
  delay(300);
   digitalWrite(8,LOW);
   Serial.println("cancello");
   TCPSerial.println("AT+CIPMODE?");
   delay("500");
   for(int i=1;i<40;i++){ data[i]= TCPSerial.read(); Serial.print(data[i]);  }
   TCPSerial.println("AT+CIPSTATUS?");
   delay("500");
   delay("1000");
if(compare.indexOf("porta")!=-1)
    digitalWrite(9,HIGH);
    delay(300);
     digitalWrite(9,LOW);
     Serial.println("porta");
   delay("500");
   delay("1000");
sorry I found the problem.....in the bottom when I checked the IPSTATUS I put question mark at the end and that was an error. Moreover I used the wrong command to send data. The correct one is
 TCPSerial.println("AT+CIPSTATUS");
   delay("500");
   for(int i=0;i<80;i++){ data2[i]=" ";}
   for(int i=1;i<80;i++){ data2[i]= TCPSerial.read(); Serial.print(data2[i]);  }
   TCPSerial.println("AT+CIPSENDEX=0,2");
   delay("1000");
   for(int i=1;i<40;i++){ data2[i]= TCPSerial.read(); Serial.print(data2[i]);  }
   delay("1000");
Thanks a lot and I hope this code can help other people
Bye!!!
